Up to 20% off select tools
HP Compaq C700 Keyboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
88
All Time:
1,464
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In this guide, you will learn how to remove the keyboard of the HP Compaq C700 laptop.
    1. HP Compaq C700 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
      • Turn off computer by pressing and holding the power button.
      Ask FixBot
    2. HP Compaq C700 Keyboard Replacement: step 2, image 1 of 3 HP Compaq C700 Keyboard Replacement: step 2, image 2 of 3 HP Compaq C700 Keyboard Replacement: step 2, image 3 of 3
      • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
      • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
      Ask FixBot
    3. HP Compaq C700 Keyboard Replacement: step 3, image 1 of 1
      • Gently lift up and remove the keyboard.
      Ask FixBot
Author
with
Taylor Johansen
720 Reputation
5 Guides authored
UMass Dartmouth, Team 5-6, Martin Fall 2016 Member of UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Members
72 Guides authored
2 Guide Comments
er zijn 3 schroeven aan het keyboard
marcel - Reply Share
there is a third screw holding in the keyboard located under the RAM cover not mentioned in this guide, please make sure you remove that too or else you may end up warping your keyboard like my friend did with his C700.
azusa - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 88
All Time: 1,464
