Up to 20% off select tools
HP Compaq C700 Battery Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
26
Past 30 Days:
102
All Time:
2,154
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
From this guide, you will learn how to locate and safely remove a battery from a HP Compaq C700 laptop.
    1. HP Compaq C700 Battery Replacement, Battery: step 1, image 1 of 1
      • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
      • Turn off computer by pressing and holding the power button.
      Ask FixBot
    2. HP Compaq C700 Battery Replacement: step 2, image 1 of 1
      • On the underside of the laptop, locate the sliding lock that keeps the battery in place.
      • Using your finger, slide the battery lock to the left to unlock the battery. Once the battery is unlocked, it is free to be removed.
      Ask FixBot
Author
with
Taylor Johansen
720 Reputation
5 Guides authored
UMass Dartmouth, Team 5-6, Martin Fall 2016 Member of UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Members
72 Guides authored
1 Guide Comment
thanks - appreciate this advice as I wasn’t able to get the battery out and thought I was missing something, but then I just tried harder!
Albert Einstein - Reply Share
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 102
All Time: 2,154
