Up to 20% off select tools
HP Compaq 6910p RAM Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
99
All Time:
4,723
Comments: 5
5 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
In this guide, we will illustrate how to remove and replace the RAM card of this device. Thumbs and a Phillips screw driver are required to replace this item.
    1. HP Compaq 6910p RAM Replacement, RAM: step 1, image 1 of 2 HP Compaq 6910p RAM Replacement, RAM: step 1, image 2 of 2
      • Loosen the 1.5 cm Phillips #1 screw.
      • Lift up the cover.
      Ask FixBot
    2. HP Compaq 6910p RAM Replacement: step 2, image 1 of 3 HP Compaq 6910p RAM Replacement: step 2, image 2 of 3 HP Compaq 6910p RAM Replacement: step 2, image 3 of 3
      • Locate the release latches marked in red.
      • Press down on the release latches simultaneously to release the RAM.
      • Remove the RAM.
      Ask FixBot
2 other people completed this guide.
Author
with
Tyler Fricks
531 Reputation
5 Guides authored
Montana Tech, Team 3-2, Shirk Fall 2015 Member of Montana Tech, Team 3-2, Shirk Fall 2015
MTUM-SHIRK-F15S3G2
5 Members
60 Guides authored
5 Guide Comments
Can The RAM in this machine run with anything more then just 2GB's? I am just wondering.
Marshall WahlstromHelgren - Reply Share
This laptop can run even 8gb ram (2x4gb), the second slot is under the keyboard.
Zar' Roc - Reply Share
How many gb of ram should be put in the back….a 4gb  or can an 8gb ram be inserted in the back so you can not have to put any more under the keyboard if you wanted to just upgrade to 8 gb at one time or 4gb at one time and not ever have to buy 2gb, 4gb or 8gb.  answer me at natefoster@bellsouth.net.  I have in my HP6910p  a 2gb ram and a small 60 harddrive and the computer seems to be slow.  Do I need to increase the ram or the harddrive  or both.  Help me with this.  I am waiting too long to start the computer up.  It is a good computer. What should I do to get more speed.
natefoster - Reply Share
where´s the second slot located?
Patrick Wirth - Reply Share
It is under the keyboard. There a few youtube videos showing how to remove the keyboard and get to the second slot.
Dynasty - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 99
All Time: 4,723
