Up to 20% off select tools
HP Compaq 6910p Processor Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
102
All Time:
5,541
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In this guide, we will illustrate how to remove and replace the processor of this device. Required tools include one Phillips screwdriver, one T9 Torx screwdriver, Arctic Silver Thermal Paste, and thumbs of course. Because the processor is difficult to find, patience will be required as well.
    1. HP Compaq 6910p Processor Replacement, Processor: step 1, image 1 of 2 HP Compaq 6910p Processor Replacement, Processor: step 1, image 2 of 2
      • Turn the laptop upside down.
      • Remove the fourteen 1.5 cm Phillips's #1 screws.
      • Remove the battery.
      • Remove three 0.3 cm Phillips #1 screws in the battery compartment.
      Ask FixBot
    2. HP Compaq 6910p Processor Replacement: step 2, image 1 of 3 HP Compaq 6910p Processor Replacement: step 2, image 2 of 3 HP Compaq 6910p Processor Replacement: step 2, image 3 of 3
      • Slide the tabs upward to release the keyboard
      • Lift up the keyboard
      • Disconnect the cables attaching the keyboard to the laptop by lifting up the release tabs.
      • Use a spudger if you're having trouble lifting up the tabs.
      Ask FixBot
    3. HP Compaq 6910p Processor Replacement: step 3, image 1 of 1
      • Remove the upper frame of the laptop
      • This part is difficult, so use a spudger if you're having trouble removing the frame.
      Ask FixBot
    4. HP Compaq 6910p Processor Replacement: step 4, image 1 of 3 HP Compaq 6910p Processor Replacement: step 4, image 2 of 3 HP Compaq 6910p Processor Replacement: step 4, image 3 of 3
      • Loosen the four 1.5 cm Phillips #1 screws indicated in red.
      • Remove the heat sink to reveal the processor.
      Ask FixBot
    5. HP Compaq 6910p Processor Replacement: step 5, image 1 of 1
      • Lift up the processor carefully to remove
      Ask FixBot
7 other people completed this guide.
Author
with
Tyler Fricks
531 Reputation
5 Guides authored
Montana Tech, Team 3-2, Shirk Fall 2015 Member of Montana Tech, Team 3-2, Shirk Fall 2015
MTUM-SHIRK-F15S3G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 102
All Time: 5,541
