Up to 20% off select tools
HP Compaq 6710b Keyboard Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
107
All Time:
6,111
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Keyboard removal is necessary to replace heat sink paste and ram.
    1. HP Compaq 6710b Keyboard Replacement, Keyboard: step 1, image 1 of 3 HP Compaq 6710b Keyboard Replacement, Keyboard: step 1, image 2 of 3 HP Compaq 6710b Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Turn off computer before starting.
      • Flip to the backside of the laptop.
      • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
      • Using the same screwdriver, unscrew the 8mm screws.
      • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
      Ask FixBot
    2. HP Compaq 6710b Keyboard Replacement: step 2, image 1 of 1
      • Flip over the laptop to the top side, and open the laptop.
      • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
      Ask FixBot
    3. HP Compaq 6710b Keyboard Replacement: step 3, image 1 of 2 HP Compaq 6710b Keyboard Replacement: step 3, image 2 of 2
      • Using the plastic prying tool, lift the keyboard gently towards you.
      • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
      Ask FixBot
    4. HP Compaq 6710b Keyboard Replacement: step 4, image 1 of 1
      • Pull up on both sides of the black locking tab of the connector.
      • The keyboard should now be free of the computer.
      Ask FixBot
4 other people completed this guide.
Author
with
Khulan Orgil
1,186 Reputation
6 Guides authored
Cal Poly, Team 4-2, Maness Spring 2015 Member of Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Members
72 Guides authored
2 Guide Comments
No parts required to *replace* the keyboard?
David - Reply Share
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - Reply Share
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 107
All Time: 6,111
