HP Compaq 6710b Heat Sink Replacement
  1. HP Compaq 6710b Heat Sink Replacement, Battery: step 1, image 1 of 1
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
    Ask FixBot
  2. HP Compaq 6710b Heat Sink Replacement, Keyboard: step 2, image 1 of 3 HP Compaq 6710b Heat Sink Replacement, Keyboard: step 2, image 2 of 3 HP Compaq 6710b Heat Sink Replacement, Keyboard: step 2, image 3 of 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
    Ask FixBot
  3. HP Compaq 6710b Heat Sink Replacement: step 3, image 1 of 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
    Ask FixBot
  4. HP Compaq 6710b Heat Sink Replacement: step 4, image 1 of 2 HP Compaq 6710b Heat Sink Replacement: step 4, image 2 of 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
    Ask FixBot
  5. HP Compaq 6710b Heat Sink Replacement: step 5, image 1 of 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
    Ask FixBot
  6. HP Compaq 6710b Heat Sink Replacement, Power Button Panel: step 6, image 1 of 1
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
    Ask FixBot
  7. HP Compaq 6710b Heat Sink Replacement: step 7, image 1 of 3 HP Compaq 6710b Heat Sink Replacement: step 7, image 2 of 3 HP Compaq 6710b Heat Sink Replacement: step 7, image 3 of 3
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
    Ask FixBot
  8. HP Compaq 6710b Heat Sink Replacement, Heat Sink: step 8, image 1 of 1
    • Using two fingers, open the prongs holding the RAM
    • Then slide the RAM out from the socket
    Ask FixBot
  9. HP Compaq 6710b Heat Sink Replacement: step 9, image 1 of 1
    • Using a Phillips #1 screwdriver, unscrew the two 7mm screws on the top and bottom of the fan.
    Ask FixBot
  10. HP Compaq 6710b Heat Sink Replacement: step 10, image 1 of 3 HP Compaq 6710b Heat Sink Replacement: step 10, image 2 of 3 HP Compaq 6710b Heat Sink Replacement: step 10, image 3 of 3
    • Using two fingers, pull out the fan power connector.
    • To take out the fan, lift the bottom of the fan and take it out at an angle.
    Ask FixBot
  11. HP Compaq 6710b Heat Sink Replacement: step 11, image 1 of 1
    • Using the Phillips #1 screwdriver, unscrew the four screws on the copper plate.
    • The screws on the copper plate do not come all the way out.
    Ask FixBot
  12. HP Compaq 6710b Heat Sink Replacement: step 12, image 1 of 2 HP Compaq 6710b Heat Sink Replacement: step 12, image 2 of 2
    • Rotate the copper plate heat sink to slide it out.
    • Do not force the heat sink because it's easy to damage.
    Ask FixBot
9 other people completed this guide.
Khulan Orgil
1,186 Reputation
6 Guides authored
Cal Poly, Team 4-2, Maness Spring 2015 Member of Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Members
6 Guides authored
3 Guide Comments
That was easy. Thanks man :)
Florian Kasimir - Reply Share
благодаря за инструкцията!
kirovr - Reply Share
Piece of cake ! Thanks. :)
Pierre Delanoy - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 40
All Time: 4,804
