HP Compaq 6510b Hard Drive Replacement
    1. HP Compaq 6510b Hard Drive Replacement, Battery: step 1, image 1 of 2 HP Compaq 6510b Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Flip the computer over so the backside is facing you.
      • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
      • Slide the battery out.
      Ask FixBot
    1. HP Compaq 6510b Hard Drive Replacement, Hard Drive: step 2, image 1 of 3 HP Compaq 6510b Hard Drive Replacement, Hard Drive: step 2, image 2 of 3 HP Compaq 6510b Hard Drive Replacement, Hard Drive: step 2, image 3 of 3
      • Flip the laptop over and locate the sign that says HP 3D DriveGuard.
      • Remove the two 5mm JIS #1 screws with your screwdriver.
      • Carefully lift up the cover.
      • Carefully lift up the hard drive from the back and pull it out.
      Ask FixBot
3 other people completed this guide.
Joseph Noudom
587 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,391
