Up to 20% off select tools
HP Compaq 6510b Fan Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
67
All Time:
1,791
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
We are going to show you how to replace the dead fan in your device.
    1. HP Compaq 6510b Fan Replacement, Battery: step 1, image 1 of 2 HP Compaq 6510b Fan Replacement, Battery: step 1, image 2 of 2
      • Flip the computer over so the backside is facing you.
      • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
      • Slide the battery out.
      Ask FixBot
    1. HP Compaq 6510b Fan Replacement, RAM: step 2, image 1 of 2 HP Compaq 6510b Fan Replacement, RAM: step 2, image 2 of 2
      • Flip your device over.
      • In the center of the bottom of the laptop, there is a panel with two screws. Using the JIS #1 screw head unscrew both.
      • Lift the panel.
      Ask FixBot
    2. HP Compaq 6510b Fan Replacement: step 3, image 1 of 3 HP Compaq 6510b Fan Replacement: step 3, image 2 of 3 HP Compaq 6510b Fan Replacement: step 3, image 3 of 3
      • The RAM is held down by two prongs. Gently pull them until the RAM pops out of place.
      • Lift the RAM out of place.
      Ask FixBot
    1. HP Compaq 6510b Fan Replacement, Fan: step 4, image 1 of 1
      • Look for tabs in between esc and f1, f4 and f5, f8 and f9, f12 and scroll.
      • Pull these tabs towards you.
      Ask FixBot
    2. HP Compaq 6510b Fan Replacement: step 5, image 1 of 2 HP Compaq 6510b Fan Replacement: step 5, image 2 of 2
      • Flip the laptop over and on the back of the center of the keyboard there is a screw with a rectangle beside it that looks like a keyboard. Remove this Phillips 5mm screw and another similar screw in the back top left of the keyboard.
      • Then carefully lift the keyboard out of place with your fingernails or a plastic opening tool.
      Ask FixBot
    3. HP Compaq 6510b Fan Replacement: step 6, image 1 of 3 HP Compaq 6510b Fan Replacement: step 6, image 2 of 3 HP Compaq 6510b Fan Replacement: step 6, image 3 of 3
      • There will be a metallic film attached to the keyboard from the motherboard. A black latch runs along the film keeping it in place. Lift the latch and detach the film; remove it to fully remove the keyboard.
      Ask FixBot
    4. HP Compaq 6510b Fan Replacement: step 7, image 1 of 3 HP Compaq 6510b Fan Replacement: step 7, image 2 of 3 HP Compaq 6510b Fan Replacement: step 7, image 3 of 3
      • Carefully undo the white film the same way you took out the metallic film
      • Once this film is removed the bar with the power button and media tools above the keyboard will pop out of place using a spudger.
      Ask FixBot
    5. HP Compaq 6510b Fan Replacement: step 8, image 1 of 2 HP Compaq 6510b Fan Replacement: step 8, image 2 of 2
      • Underneath, a metal clamp will be revealed with two Torx Security T7 17mm screws. Unscrew these.
      • Carefully lift the cable out of place that is to the right of it.
      Ask FixBot
    6. HP Compaq 6510b Fan Replacement: step 9, image 1 of 2 HP Compaq 6510b Fan Replacement: step 9, image 2 of 2
      • Unscrew these two JIS #1 5mm screws on the fan.
      • Carefully unplug the fans' wires.
      • Remove the fan and put in new one.
      Ask FixBot
2 other people completed this guide.
Author
with
Joseph Noudom
587 Reputation
4 Guides authored
1 Guide Comment
Many Thanks!
BTW, my German keyboard was held by a 3rd screw. In step 3, one needs to remove the remaining screw next to the WIFI module as well.
Torsten Spengler - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 67
All Time: 1,791
