HP Compaq 6510b CD Drive Replacement
    1. HP Compaq 6510b CD Drive Replacement, Battery: step 1, image 1 of 2 HP Compaq 6510b CD Drive Replacement, Battery: step 1, image 2 of 2
      • Flip the computer over so the backside is facing you.
      • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
      • Slide the battery out.
      Ask FixBot
    1. HP Compaq 6510b CD Drive Replacement, Fan: step 2, image 1 of 1
      • Look for tabs in between esc and f1, f4 and f5, f8 and f9, f12 and scroll.
      • Pull these tabs towards you.
      Ask FixBot
    2. HP Compaq 6510b CD Drive Replacement: step 3, image 1 of 2 HP Compaq 6510b CD Drive Replacement: step 3, image 2 of 2
      • Flip the laptop over and on the back of the center of the keyboard there is a screw with a rectangle beside it that looks like a keyboard. Remove this Phillips 5mm screw and another similar screw in the back top left of the keyboard.
      • Then carefully lift the keyboard out of place with your fingernails or a plastic opening tool.
      Ask FixBot
    3. HP Compaq 6510b CD Drive Replacement: step 4, image 1 of 3 HP Compaq 6510b CD Drive Replacement: step 4, image 2 of 3 HP Compaq 6510b CD Drive Replacement: step 4, image 3 of 3
      • There will be a metallic film attached to the keyboard from the motherboard. A black latch runs along the film keeping it in place. Lift the latch and detach the film; remove it to fully remove the keyboard.
      Ask FixBot
    4. HP Compaq 6510b CD Drive Replacement: step 5, image 1 of 3 HP Compaq 6510b CD Drive Replacement: step 5, image 2 of 3 HP Compaq 6510b CD Drive Replacement: step 5, image 3 of 3
      • Carefully undo the white film the same way you took out the metallic film
      • Once this film is removed the bar with the power button and media tools above the keyboard will pop out of place using a spudger.
      Ask FixBot
    5. HP Compaq 6510b CD Drive Replacement: step 6, image 1 of 2 HP Compaq 6510b CD Drive Replacement: step 6, image 2 of 2
      • Underneath, a metal clamp will be revealed with two Torx Security T7 17mm screws. Unscrew these.
      • Carefully lift the cable out of place that is to the right of it.
      Ask FixBot
    6. HP Compaq 6510b CD Drive Replacement: step 7, image 1 of 2 HP Compaq 6510b CD Drive Replacement: step 7, image 2 of 2
      • Unscrew these two JIS #1 5mm screws on the fan.
      • Carefully unplug the fans' wires.
      • Remove the fan and put in new one.
      Ask FixBot
    1. HP Compaq 6510b CD Drive Replacement, CD Drive: step 8, image 1 of 3 HP Compaq 6510b CD Drive Replacement, CD Drive: step 8, image 2 of 3 HP Compaq 6510b CD Drive Replacement, CD Drive: step 8, image 3 of 3
      • Push the CD drive out using your finger.
      Ask FixBot
Joseph Noudom
587 Reputation
4 Guides authored
1 Guide Comment
I don’t know why these instructions are suggested but this is how you actually remove the disc drive. https://www.youtube.com/watch?v=gTvAt3Nn...
Cretien - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 1,062
