HP Compaq 2510p Bluetooth Adapter Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
80
All Time:
820
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show step-by-step instructions to replace the bluetooth adapter in the HP Compaq 2510p. .
Tools
    1. HP Compaq 2510p Bluetooth Adapter Replacement, Bluetooth Adapter: step 1, image 1 of 1
      • Place the laptop upside down, with the battery facing away from you. Towards the bottom-middle of the laptop, you should see a small panel with a Bluetooth symbol.
      Ask FixBot
    2. HP Compaq 2510p Bluetooth Adapter Replacement: step 2, image 1 of 1
      • There is 1 screw on the panel you located in step one. Use your Philips head screwdriver to remove the single screw.
      Ask FixBot
    3. HP Compaq 2510p Bluetooth Adapter Replacement: step 3, image 1 of 1
      • Remove the Bluetooth panel by pulling it with your finger.
      • Pull gently as there is a wire connecting the laptop and the adapter.
      Ask FixBot
    4. HP Compaq 2510p Bluetooth Adapter Replacement: step 4, image 1 of 1
      • Pull the adapter to the left exposing its underside. Locate and remove its only screw using your Phillip's head screwdriver.
      Ask FixBot
    5. HP Compaq 2510p Bluetooth Adapter Replacement: step 5, image 1 of 1
      • Separate the Bluetooth adapter by pulling it from its casing.
      Ask FixBot
    6. HP Compaq 2510p Bluetooth Adapter Replacement: step 6, image 1 of 1
      • Remove the adapter by pulling on the base of the connecting wires and the adapter, in opposite directions.
      • Use moderate force.
      Ask FixBot
3 other people completed this guide.
Derek Kohansky
297 Reputation
2 Guides authored
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 80
All Time: 820
