HP Chromebox J5N50UT Bottom Cover Replacement
  1. HP Chromebox J5N50UT Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 1
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
    Ask FixBot
  2. HP Chromebox J5N50UT Bottom Cover Replacement: step 2, image 1 of 1
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
    Ask FixBot
  3. HP Chromebox J5N50UT Bottom Cover Replacement: step 3, image 1 of 1
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
    Ask FixBot
  4. HP Chromebox J5N50UT Bottom Cover Replacement: step 4, image 1 of 1
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
    Ask FixBot
Ashley Marvin
685 Reputation
5 Guides authored
Ohio State, Team S1-G3, Whitney Fall 2018 Member of Ohio State, Team S1-G3, Whitney Fall 2018
OSU-WHITNEY-F18S1G3
2 Members
5 Guides authored
1 Guide Comment
Can you explain how/where the integrated VESA mount is?
Is the mounting screw holes under the rubber feet, like other chromeboxes, from other makers?
When Ze - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 991
