HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement
    1. HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement, Lower Case: step 1, image 1 of 2 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement, Lower Case: step 1, image 2 of 2
      • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
      • Lay the device down so the lower case is facing up.
      Ask FixBot
    2. HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 2, image 1 of 3 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 2, image 2 of 3 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 2, image 3 of 3
      • Use a Phillips screwdriver to remove four 6.6 mm screws that secure the lower case.
      Ask FixBot
    3. HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 3, image 1 of 3 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 3, image 2 of 3 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 3, image 3 of 3
      • Insert an opening tool into the seam between the lower case and the chassis, near the hinge.
      • Pry around the entire perimeter of the lower case until it fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement, Wi-Fi module: step 4, image 1 of 3 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement, Wi-Fi module: step 4, image 2 of 3 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement, Wi-Fi module: step 4, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the one 4.1 mm screw that secures the metal bracket on top of the Wi-Fi module.
      Ask FixBot
    2. HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 5, image 1 of 2 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 5, image 2 of 2
      • Grasp and remove the metal bracket.
      Ask FixBot
    3. HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 6, image 1 of 2 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 6, image 2 of 2
      • Use angled tweezers to lift up and disconnect the lower Wi-Fi module coaxial connector.
      Ask FixBot
    4. HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 7, image 1 of 3 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 7, image 2 of 3 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 7, image 3 of 3
      • Use angled tweezers to lift up and disconnect the upper Wi-Fi module coaxial connector.
      Ask FixBot
    5. HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 8, image 1 of 3 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 8, image 2 of 3 HP Chromebook 15a-nb0013dx Wi-Fi Module Replacement: step 8, image 3 of 3
      • Grasp the Wi-Fi module and pull it directly out of its socket.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Sahid
957 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 31
All Time: 260
