HP Chromebook 14-x013dx Screen Replacement
  1. HP Chromebook 14-x013dx Screen Replacement, Screen: step 1, image 1 of 3 HP Chromebook 14-x013dx Screen Replacement, Screen: step 1, image 2 of 3 HP Chromebook 14-x013dx Screen Replacement, Screen: step 1, image 3 of 3
    • Remove lower left and right nylon flaps on the screen to remove the screws located underneath them.
    • The nylon strips on the side may be difficult to remove, as they are held on with adhesive. A spudger can be used to help remove these strips before removing with fingers.
    • Remove the two 2mm screws holding the bezel to the laptop case.
  2. HP Chromebook 14-x013dx Screen Replacement: step 2, image 1 of 2 HP Chromebook 14-x013dx Screen Replacement: step 2, image 2 of 2
    • Gently pry around the edges of the display using a spudger to remove the bezel that borders the screen.
  3. HP Chromebook 14-x013dx Screen Replacement: step 3, image 1 of 2 HP Chromebook 14-x013dx Screen Replacement: step 3, image 2 of 2
    • Remove glued plastic at the bottom of the cover.
  4. HP Chromebook 14-x013dx Screen Replacement: step 4, image 1 of 1
    • Once glue is separated, pop out the front cover by pulling upwards on the hinge.
  5. HP Chromebook 14-x013dx Screen Replacement: step 5, image 1 of 2 HP Chromebook 14-x013dx Screen Replacement: step 5, image 2 of 2
    • Once the bezel has been removed, remove the four 5mm screws at the corners of the screen using a PH00 screwdriver.
  6. HP Chromebook 14-x013dx Screen Replacement: step 6, image 1 of 3 HP Chromebook 14-x013dx Screen Replacement: step 6, image 2 of 3 HP Chromebook 14-x013dx Screen Replacement: step 6, image 3 of 3
    • Before completely removing the screen, detach the connected located at the bottom of the screen.
    • The connection to be removed should have a barcode marking.
3 other people completed this guide.
NHerbert
602 Reputation
5 Guides authored
USF Tampa, Team S3-G6, Nance Fall 2017 Member of USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 69
All Time: 2,213
