HP Chromebook 14-q010nr Key Replacement
  1. HP Chromebook 14-q010nr Key Replacement, Key: step 1, image 1 of 2 HP Chromebook 14-q010nr Key Replacement, Key: step 1, image 2 of 2
    • Press on a key above the key you want to replace.
    • Place a flat object, like an iFixit opening tool in this case, under the broken key and lift upwards to remove it.
    Ask FixBot
  2. HP Chromebook 14-q010nr Key Replacement: step 2, image 1 of 1
    • Align the square plastic bracket to make sure the keys fits there if the bracket moved.
    • Note for missing keys: if this is missing, purchase a new one and align and insert in missing key area.
    Ask FixBot
  3. HP Chromebook 14-q010nr Key Replacement: step 3, image 1 of 3 HP Chromebook 14-q010nr Key Replacement: step 3, image 2 of 3 HP Chromebook 14-q010nr Key Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Place the new key gently into place. Tweezers can help with the process.
    • Align the new key in the area and press on it to attach it in place.
    • It may not attach until you hear a click or snap noise, so take your time attaching the new key.
    • Do not press too hard on the new key lest you break it.
    Ask FixBot
To reassemble your device, follow these steps in reverse order.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 26
All Time: 412
