HP Chromebook 14-ca061dx Keyboard Replacement
  1. HP Chromebook 14-ca061dx Keyboard Replacement, Keyboard: step 1, image 1 of 3 HP Chromebook 14-ca061dx Keyboard Replacement, Keyboard: step 1, image 2 of 3 HP Chromebook 14-ca061dx Keyboard Replacement, Keyboard: step 1, image 3 of 3
    Tool used on this step:
    $3.99
    Buy
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
    Ask FixBot
  2. HP Chromebook 14-ca061dx Keyboard Replacement: step 2, image 1 of 3 HP Chromebook 14-ca061dx Keyboard Replacement: step 2, image 2 of 3 HP Chromebook 14-ca061dx Keyboard Replacement: step 2, image 3 of 3
    • Remove the two bigger rubber stoppers using a metal spudger.
    Ask FixBot
  3. HP Chromebook 14-ca061dx Keyboard Replacement: step 3, image 1 of 2 HP Chromebook 14-ca061dx Keyboard Replacement: step 3, image 2 of 2
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
    Ask FixBot
  4. HP Chromebook 14-ca061dx Keyboard Replacement: step 4, image 1 of 2 HP Chromebook 14-ca061dx Keyboard Replacement: step 4, image 2 of 2
    • Remove the two 9mm Phillips #1 screws.
    Ask FixBot
  5. HP Chromebook 14-ca061dx Keyboard Replacement: step 5, image 1 of 3 HP Chromebook 14-ca061dx Keyboard Replacement: step 5, image 2 of 3 HP Chromebook 14-ca061dx Keyboard Replacement: step 5, image 3 of 3
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
    Ask FixBot
  6. HP Chromebook 14-ca061dx Keyboard Replacement: step 6, image 1 of 3 HP Chromebook 14-ca061dx Keyboard Replacement: step 6, image 2 of 3 HP Chromebook 14-ca061dx Keyboard Replacement: step 6, image 3 of 3
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
    Ask FixBot
  7. HP Chromebook 14-ca061dx Keyboard Replacement: step 7, image 1 of 3 HP Chromebook 14-ca061dx Keyboard Replacement: step 7, image 2 of 3 HP Chromebook 14-ca061dx Keyboard Replacement: step 7, image 3 of 3
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
    Ask FixBot
  8. HP Chromebook 14-ca061dx Keyboard Replacement: step 8, image 1 of 1
    • Lift the rest of the keyboard up from the base of the Chromebook.
    Ask FixBot
Jean Arevalo
787 Reputation
6 Guides authored
1 Guide Comment
good afternoon, excuse me, I have a question, I also have the same brand HP Chromebook 14-ca061dx and I just want to know where the anti-write screw is, I want to remove the anti-write screw to install windows 10..
Marcos Perea - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 32
All Time: 1,686
