HP Chromebook 14-ca061dx Display Replacement
  1. HP Chromebook 14-ca061dx Display Replacement, Display: step 1, image 1 of 3 HP Chromebook 14-ca061dx Display Replacement, Display: step 1, image 2 of 3 HP Chromebook 14-ca061dx Display Replacement, Display: step 1, image 3 of 3
    • Flip the Chromebook so that the underside is facing upwards.
    • Follow along the edge with the iFixit opening tool to unhinge the display frame.
  2. HP Chromebook 14-ca061dx Display Replacement: step 2, image 1 of 1
    • Flip the Chromebook right side up and open it to form a 180 degree angle.
  3. HP Chromebook 14-ca061dx Display Replacement: step 3, image 1 of 1
    • Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
    • The bottom edge of the bezel may stick because there is glue holding it together.
  4. HP Chromebook 14-ca061dx Display Replacement: step 4, image 1 of 2 HP Chromebook 14-ca061dx Display Replacement: step 4, image 2 of 2
    • Use spudger or the iFixit opening tool to remove the bezel.
    • When prying, be careful not to damage or snap bezel. This is made up of very, thin plastic.
    • Pull bezel from the bottom, once all clips are detached.
    • Remove bezel.
  5. HP Chromebook 14-ca061dx Display Replacement: step 5, image 1 of 2 HP Chromebook 14-ca061dx Display Replacement: step 5, image 2 of 2
    • Remove the four 2mm JIS #000 screws.
  6. HP Chromebook 14-ca061dx Display Replacement: step 6, image 1 of 2 HP Chromebook 14-ca061dx Display Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
    • Be cautious when pulling back the tape—the connector/ribbon is fragile and could snap easily.
  7. HP Chromebook 14-ca061dx Display Replacement: step 7, image 1 of 1
    • Remove the LCD/display panel from the Chromebook frame.
Jean Arevalo
787 Reputation
6 Guides authored
1 Guide Comment
should disconnect the laptop battery first
TJ Kleckner - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 39
All Time: 3,256
