HP Chromebook 14-ak041dx RAM Replacement
  1. HP Chromebook 14-ak041dx RAM Replacement, Keyboard: step 1, image 1 of 2 HP Chromebook 14-ak041dx RAM Replacement, Keyboard: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • You will need a pair of tweezers and a Phillips screwdriver.
    • Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
    Ask FixBot
  2. HP Chromebook 14-ak041dx RAM Replacement: step 2, image 1 of 3 HP Chromebook 14-ak041dx RAM Replacement: step 2, image 2 of 3 HP Chromebook 14-ak041dx RAM Replacement: step 2, image 3 of 3
    • Using a pair of tweezers, remove the five grey silicone covers.
    • Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
    • Place them aside where they will not be lost.
    Ask FixBot
  3. HP Chromebook 14-ak041dx RAM Replacement: step 3, image 1 of 3 HP Chromebook 14-ak041dx RAM Replacement: step 3, image 2 of 3 HP Chromebook 14-ak041dx RAM Replacement: step 3, image 3 of 3
    • Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
    • Place the keyboard aside. Inspect for any visual damage or marks.
    Ask FixBot
  4. HP Chromebook 14-ak041dx RAM Replacement, Battery: step 4, image 1 of 2 HP Chromebook 14-ak041dx RAM Replacement, Battery: step 4, image 2 of 2
    • Remove the four 3mm Phillips #000 screws holding the battery in place.
    Ask FixBot
  5. HP Chromebook 14-ak041dx RAM Replacement: step 5, image 1 of 3 HP Chromebook 14-ak041dx RAM Replacement: step 5, image 2 of 3 HP Chromebook 14-ak041dx RAM Replacement: step 5, image 3 of 3
    Buy
    • Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
    • Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
    Ask FixBot
  6. HP Chromebook 14-ak041dx RAM Replacement: step 6, image 1 of 1
    • Carefully lift the battery out of the laptop.
    Ask FixBot
  7. HP Chromebook 14-ak041dx RAM Replacement, Heat Sink: step 7, image 1 of 3 HP Chromebook 14-ak041dx RAM Replacement, Heat Sink: step 7, image 2 of 3 HP Chromebook 14-ak041dx RAM Replacement, Heat Sink: step 7, image 3 of 3
    • Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
    • Remove the heat sink from the laptop.
    Ask FixBot
  8. HP Chromebook 14-ak041dx RAM Replacement, Wireless Card: step 8, image 1 of 2 HP Chromebook 14-ak041dx RAM Replacement, Wireless Card: step 8, image 2 of 2
    • Remove the single 2.5mm Phillips #00 screw from the wireless card.
    • Gently pull the wireless card from the motherboard to remove it.
    Ask FixBot
  9. HP Chromebook 14-ak041dx RAM Replacement, Motherboard: step 9, image 1 of 3 HP Chromebook 14-ak041dx RAM Replacement, Motherboard: step 9, image 2 of 3 HP Chromebook 14-ak041dx RAM Replacement, Motherboard: step 9, image 3 of 3
    Buy
    • Gently pull the wire connector with a pair of tweezers to free it from the motherboard.
    • Use a pair of tweezers to remove the black ribbon cable from its connector.
    • Use the tweezers to detach the wire connector from the bottom left corner of the motherboard.
    Ask FixBot
  10. HP Chromebook 14-ak041dx RAM Replacement: step 10, image 1 of 3 HP Chromebook 14-ak041dx RAM Replacement: step 10, image 2 of 3 HP Chromebook 14-ak041dx RAM Replacement: step 10, image 3 of 3
    • Remove the four Phillips #000 screws holding the motherboard in place.
    • Remove the motherboard from the laptop.
    Ask FixBot
  11. HP Chromebook 14-ak041dx RAM Replacement, RAM: step 11, image 1 of 1
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 1,570
