HP Chromebook 14-SMB Keyboard Replacement
    1. HP Chromebook 14-SMB Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Remove the eleven Phillips screws securing the lower case.
      • Remove the two rubber stoppers, then remove the two Phillips screws hidden underneath.
      Ask FixBot
    2. HP Chromebook 14-SMB Keyboard Replacement: step 2, image 1 of 2 HP Chromebook 14-SMB Keyboard Replacement: step 2, image 2 of 2
      • Flip the laptop over and open the lid.
      • Insert an opening pick into the seam between the keyboard assembly and chassis.
      • Slide the pick along the edge to release the plastic clips, then use an opening tool to pry around the entire perimeter until the keyboard assembly fully releases.
      Ask FixBot
    3. HP Chromebook 14-SMB Keyboard Replacement: step 3, image 1 of 2 HP Chromebook 14-SMB Keyboard Replacement: step 3, image 2 of 2
      • Do not pull the keyboard assembly fully away from the laptop yet; it is still connected by fragile ribbon cables.
      • Lift the keyboard perpendicular to the laptop.
      • Flip up each of the two black ZIF locking flaps that secure the keyboard and trackpad ribbon cables to their motherboard sockets.
      • Disconnect the keyboard and trackpad ribbon cables.
      • Remove the keyboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Marissa Torres
232 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 77
All Time: 387
