HP Chromebook 14-SMB Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
63
All Time:
306
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 2 hours
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Before replacing your HP Chromebook 14-SMB fan, consider other methods to improve cooling functions listed on HP's help center: https://h30434.www3.hp.com/t5/Notebook-B...
Use this guide to replace a faulty fan in a HP Chromebook 14-SMB to avoid overheating and ensure proper performance. In addition to overheating, symptoms of a broken fan in a HP Chromebook 14-SMB can include: unexpected shutdowns, poor performance, and or potential hardware failure.
Parts
Tools
    1. HP Chromebook 14-SMB Fan Replacement, Keyboard: step 1, image 1 of 1
      • Remove the eleven Phillips screws securing the lower case.
      • Remove the two rubber stoppers, then remove the two Phillips screws hidden underneath.
      Ask FixBot
    2. HP Chromebook 14-SMB Fan Replacement: step 2, image 1 of 2 HP Chromebook 14-SMB Fan Replacement: step 2, image 2 of 2
      • Flip the laptop over and open the lid.
      • Insert an opening pick into the seam between the keyboard assembly and chassis.
      • Slide the pick along the edge to release the plastic clips, then use an opening tool to pry around the entire perimeter until the keyboard assembly fully releases.
      Ask FixBot
    3. HP Chromebook 14-SMB Fan Replacement: step 3, image 1 of 2 HP Chromebook 14-SMB Fan Replacement: step 3, image 2 of 2
      • Do not pull the keyboard assembly fully away from the laptop yet; it is still connected by fragile ribbon cables.
      • Lift the keyboard perpendicular to the laptop.
      • Flip up each of the two black ZIF locking flaps that secure the keyboard and trackpad ribbon cables to their motherboard sockets.
      • Disconnect the keyboard and trackpad ribbon cables.
      • Remove the keyboard.
      Ask FixBot
    1. HP Chromebook 14-SMB Fan Replacement, Battery: step 4, image 1 of 1
      • Use your fingernail or the flat end of a spudger to gently disconnect the battery connector from its motherboard connector.
      Ask FixBot
    2. HP Chromebook 14-SMB Fan Replacement: step 5, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the three screws that secure the battery.
      Ask FixBot
    3. HP Chromebook 14-SMB Fan Replacement: step 6, image 1 of 1
      • Lift the battery up and out of the chassis.
      • Take care not to scratch or damage the battery. Lithium-Ion batteries can be dangerous if punctured.
      Ask FixBot
    1. HP Chromebook 14-SMB Fan Replacement, Fan: step 7, image 1 of 1
      • Remove three Phillips screws that secure the fan.
      • Dislodge the cables around the fan from their retaining hooks.
      Ask FixBot
    2. HP Chromebook 14-SMB Fan Replacement: step 8, image 1 of 2 HP Chromebook 14-SMB Fan Replacement: step 8, image 2 of 2
      • Use your fingernail or the flat end of a spudger to disconnect the fan connector from its motherboard socket.
      Ask FixBot
    3. HP Chromebook 14-SMB Fan Replacement: step 9, image 1 of 1
      • Lift the fan up and out of the chassis.
      • Take extra care to not damage the vent towards the front of the fan.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
aurora
99 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 63
All Time: 306
