Remove the eleven Phillips screws securing the lower case.
Remove the two rubber stoppers, then remove the two Phillips screws hidden underneath.
Use your fingernail or the flat end of a spudger to gently disconnect the battery connector from its motherboard connector.
Lift the black ZIF locking flap on the daughterboard.
Disconnect the ribbon cable.
Remove the single screw near the SD card with a Phillips #0 screwdriver.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
