Up to 20% off select tools
HP Chromebook 14-Q010DX Battery Replacement
Views: 15K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
104
All Time:
14,674
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide will require removal of 1x5mm screws. Be careful removing the wires, be sure to release them as instructed before pulling on them.
    1. HP Chromebook 14-Q010DX Battery Replacement, Keyboard and Touchpad: step 1, image 1 of 2 HP Chromebook 14-Q010DX Battery Replacement, Keyboard and Touchpad: step 1, image 2 of 2
      • Flip the laptop so the base of the laptop is facing you.
      • Using the #00 screwdriver, unscrew the 13 screws.
      Ask FixBot
    2. HP Chromebook 14-Q010DX Battery Replacement: step 2, image 1 of 3 HP Chromebook 14-Q010DX Battery Replacement: step 2, image 2 of 3 HP Chromebook 14-Q010DX Battery Replacement: step 2, image 3 of 3
      • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
      • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
      Ask FixBot
    3. HP Chromebook 14-Q010DX Battery Replacement: step 3, image 1 of 3 HP Chromebook 14-Q010DX Battery Replacement: step 3, image 2 of 3 HP Chromebook 14-Q010DX Battery Replacement: step 3, image 3 of 3
      • Warning! Handle the flaps and ribbon cables with care to prevent damage.
      • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
      • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
      • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
      Ask FixBot
    4. HP Chromebook 14-Q010DX Battery Replacement: step 4, image 1 of 1
      • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
      • The tape has no function other than to keep the wire tucked away.
      Ask FixBot
    5. HP Chromebook 14-Q010DX Battery Replacement: step 5, image 1 of 1
      • Set aside the detached keyboard.
      Ask FixBot
    1. HP Chromebook 14-Q010DX Battery Replacement, Speaker: step 6, image 1 of 3 HP Chromebook 14-Q010DX Battery Replacement, Speaker: step 6, image 2 of 3 HP Chromebook 14-Q010DX Battery Replacement, Speaker: step 6, image 3 of 3
      • Undo the black tape located on the bottom from the frame of the laptop.
      • Using fingers or the spudger, slide out the black connector indicated on the left.
      • Use a #00 screwdriver to remove the two screws.
      Ask FixBot
    2. HP Chromebook 14-Q010DX Battery Replacement: step 7, image 1 of 2 HP Chromebook 14-Q010DX Battery Replacement: step 7, image 2 of 2
      • Gently remove the speakers.
      Ask FixBot
    1. HP Chromebook 14-Q010DX Battery Replacement, Battery: step 8, image 1 of 2 HP Chromebook 14-Q010DX Battery Replacement, Battery: step 8, image 2 of 2
      • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
      • Lift the black flaps and gently pull the strip out.
      • Set the strip aside.
      Ask FixBot
    2. HP Chromebook 14-Q010DX Battery Replacement: step 9, image 1 of 3 HP Chromebook 14-Q010DX Battery Replacement: step 9, image 2 of 3 HP Chromebook 14-Q010DX Battery Replacement: step 9, image 3 of 3
      • Remove the screw.
      • Use your fingers to pull the white tab out of the black slot above the battery.
      Ask FixBot
    3. HP Chromebook 14-Q010DX Battery Replacement: step 10, image 1 of 1
      • Gently remove battery.
      Ask FixBot
6 other people completed this guide.
Author
with
Kevin Piper
1,602 Reputation
6 Guides authored
USF Tampa, Team 17-2, Watkins Winter 2015 Member of USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Members
96 Guides authored
3 Guide Comments
Nice guide, guys!
dergrossmeister50 - Reply Share
Thanks, hope it made life a bit easier for you!
Kevin Piper - Reply Share
Very clear and concise. Nice going! Thank you.
sparkydog1725 - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 104
All Time: 14,674
