HP Chromebook 14 G4 Battery Replacement
  1. HP Chromebook 14 G4 Battery Replacement, Keyboard Assembly: step 1, image 1 of 2 HP Chromebook 14 G4 Battery Replacement, Keyboard Assembly: step 1, image 2 of 2
    • Remove the thirteen 2.5 mm Phillips #0 screws on the underside of the laptop that secure the keyboard assembly.
    • Flip the laptop over and open the lid.
    • Insert a nylon spudger in the gap between the keyboard assembly and lower case.
    • Gently pry around the entire perimeter until the keyboard assembly fully releases.
    Ask FixBot
  2. HP Chromebook 14 G4 Battery Replacement: step 2, image 1 of 3 HP Chromebook 14 G4 Battery Replacement: step 2, image 2 of 3 HP Chromebook 14 G4 Battery Replacement: step 2, image 3 of 3
    • Slightly lift the keyboard assembly with care not to strain the attached ribbon cables.
    • Flip up the two black ZIF locking flaps that secure the keyboard and touchpad ribbon cables to their motherboard sockets.
    • Gently pull the keyboard and touchpad ribbon cables out of their motherboard sockets.
    Ask FixBot
  3. HP Chromebook 14 G4 Battery Replacement: step 3, image 1 of 1
    • Lift the keyboard assembly off of the chassis.
    Ask FixBot
  4. HP Chromebook 14 G4 Battery Replacement, Battery: step 4, image 1 of 2 HP Chromebook 14 G4 Battery Replacement, Battery: step 4, image 2 of 2
    • Use your fingernails to "walk" the battery connector out of its socket.
    • Avoid pulling on the wires.
    Ask FixBot
  5. HP Chromebook 14 G4 Battery Replacement: step 5, image 1 of 1
    • Remove the four 4.1 mm screws securing the battery with a Phillips #00 screwdriver.
    Ask FixBot
  6. HP Chromebook 14 G4 Battery Replacement: step 6, image 1 of 2 HP Chromebook 14 G4 Battery Replacement: step 6, image 2 of 2
    • Use a nylon spudger or your fingernail to flip up the two black ZIF locking flaps that secure either end of the ribbon cable.
    • Grip each blue pull tab and gently remove the ribbon cables from their sockets.
    Ask FixBot
  7. HP Chromebook 14 G4 Battery Replacement: step 7, image 1 of 2 HP Chromebook 14 G4 Battery Replacement: step 7, image 2 of 2
    • Lift the battery up and out of the chassis.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Christian Leaman
551 Reputation
3 Guides authored
Gateway, Team 8-3, Gonzalez Fall 2024 Member of Gateway, Team 8-3, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G3
5 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 338
