HP Chromebook 11-v002dx Screen Replacement
  1. HP Chromebook 11-v002dx Screen Replacement, Screen: step 1, image 1 of 1
    • Insert your spudger between the plastic covering and the back of the case.
    Ask FixBot
  2. HP Chromebook 11-v002dx Screen Replacement: step 2, image 1 of 1
    • With the help of your spudger completely remove the plastic cover from the rest of the case.
    Ask FixBot
  3. HP Chromebook 11-v002dx Screen Replacement: step 3, image 1 of 1
    • Your screen will look like this.
    Ask FixBot
  4. HP Chromebook 11-v002dx Screen Replacement: step 4, image 1 of 2 HP Chromebook 11-v002dx Screen Replacement: step 4, image 2 of 2
    • Using a Phillips #0 Screwdriver, remove the four 2.5mm screws holding the screen in place.
    Ask FixBot
  5. HP Chromebook 11-v002dx Screen Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the tape covering the wiring and detach the ribbon cable that secures the screen to the motherboard.
    • Use tweezers if you can't reach it with your fingers.
    Ask FixBot
  6. HP Chromebook 11-v002dx Screen Replacement: step 6, image 1 of 2 HP Chromebook 11-v002dx Screen Replacement: step 6, image 2 of 2
    • Remove the display and the case.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 356
