HP Chromebook 11 G8 EE Screen Replacement
  1. HP Chromebook 11 G8 EE Screen Replacement, Keyboard & Touchpad Assembly: step 1, image 1 of 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
    Ask FixBot
  2. HP Chromebook 11 G8 EE Screen Replacement: step 2, image 1 of 2 HP Chromebook 11 G8 EE Screen Replacement: step 2, image 2 of 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
    Ask FixBot
  3. HP Chromebook 11 G8 EE Screen Replacement: step 3, image 1 of 3 HP Chromebook 11 G8 EE Screen Replacement: step 3, image 2 of 3 HP Chromebook 11 G8 EE Screen Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
    Ask FixBot
  4. HP Chromebook 11 G8 EE Screen Replacement, Bezel: step 4, image 1 of 2 HP Chromebook 11 G8 EE Screen Replacement, Bezel: step 4, image 2 of 2
    • Using your hands, pry off the hinge cover by lifting it.
    Ask FixBot
  5. HP Chromebook 11 G8 EE Screen Replacement: step 5, image 1 of 3 HP Chromebook 11 G8 EE Screen Replacement: step 5, image 2 of 3 HP Chromebook 11 G8 EE Screen Replacement: step 5, image 3 of 3
    • Using the opening tool, pry the bezel away from the top case.
    • This requires firm, constant pressure. Be careful not to break the bezel.
    Ask FixBot
  6. HP Chromebook 11 G8 EE Screen Replacement: step 6, image 1 of 1
    • Pull the bezel toward you.
    • Peel it away from the screen gently.
    Ask FixBot
  7. HP Chromebook 11 G8 EE Screen Replacement: step 7, image 1 of 1
    • Completely remove the bezel.
    Ask FixBot
  8. HP Chromebook 11 G8 EE Screen Replacement, Screen: step 8, image 1 of 1
    • Remove the four 3.5 mm screws with a Phillips #1 screwdriver.
    Ask FixBot
  9. HP Chromebook 11 G8 EE Screen Replacement: step 9, image 1 of 1
    • Flip the screen toward you.
    Ask FixBot
  10. HP Chromebook 11 G8 EE Screen Replacement: step 10, image 1 of 3 HP Chromebook 11 G8 EE Screen Replacement: step 10, image 2 of 3 HP Chromebook 11 G8 EE Screen Replacement: step 10, image 3 of 3
    Buy
    • Use tweezers to peel away the black tape holding the connector.
    Ask FixBot
  11. HP Chromebook 11 G8 EE Screen Replacement: step 11, image 1 of 3 HP Chromebook 11 G8 EE Screen Replacement: step 11, image 2 of 3 HP Chromebook 11 G8 EE Screen Replacement: step 11, image 3 of 3
    • Use the tweezers to pull away the tan tape.
    • You should see the colored wires of the connector.
    Ask FixBot
  12. HP Chromebook 11 G8 EE Screen Replacement: step 12, image 1 of 2 HP Chromebook 11 G8 EE Screen Replacement: step 12, image 2 of 2
    • Using the tweezers, lift up the small red latch on the connector.
    • Pull off the connector.
    Ask FixBot
  13. HP Chromebook 11 G8 EE Screen Replacement: step 13, image 1 of 1
    • Remove the screen.
    Ask FixBot
Isabella Brown
312 Reputation
2 Guides authored
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 35
All Time: 2,670
