HP Chromebook 11 G5 Keyboard Replacement
  1. HP Chromebook 11 G5 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
    Ask FixBot
  2. HP Chromebook 11 G5 Keyboard Replacement: step 2, image 1 of 1
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
    Ask FixBot
  3. HP Chromebook 11 G5 Keyboard Replacement: step 3, image 1 of 1
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
    Ask FixBot
  4. HP Chromebook 11 G5 Keyboard Replacement: step 4, image 1 of 1
    • Flip the device upright and open the screen as far back as possible.
    Ask FixBot
  5. HP Chromebook 11 G5 Keyboard Replacement: step 5, image 1 of 1
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
    Ask FixBot
  6. HP Chromebook 11 G5 Keyboard Replacement: step 6, image 1 of 1
    • Gently lift the keyboard assembly slightly above the base of the device.
    Ask FixBot
  7. HP Chromebook 11 G5 Keyboard Replacement: step 7, image 1 of 1
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
    Ask FixBot
  8. HP Chromebook 11 G5 Keyboard Replacement: step 8, image 1 of 1
    • Gently remove the keyboard assembly by hand from the base of the device.
    Ask FixBot
4 other people completed this guide.
Salma Zitoun
385 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 45
All Time: 1,467
