HP Chromebook 11 G4 Battery Replacement
  1. HP Chromebook 11 G4 Battery Replacement, Keyboard: step 1, image 1 of 1
    • Position the closed Chromebook with the rubber pads are facing up.
    Ask FixBot
  2. HP Chromebook 11 G4 Battery Replacement: step 2, image 1 of 2 HP Chromebook 11 G4 Battery Replacement: step 2, image 2 of 2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
    Ask FixBot
  3. HP Chromebook 11 G4 Battery Replacement: step 3, image 1 of 2 HP Chromebook 11 G4 Battery Replacement: step 3, image 2 of 2
    • Remove the eleven 6mm Phillips #1 screws.
    Ask FixBot
  4. HP Chromebook 11 G4 Battery Replacement: step 4, image 1 of 1
    • Flip over the Chromebook and open it.
    Ask FixBot
  5. HP Chromebook 11 G4 Battery Replacement: step 5, image 1 of 2 HP Chromebook 11 G4 Battery Replacement: step 5, image 2 of 2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
    Ask FixBot
  6. HP Chromebook 11 G4 Battery Replacement: step 6, image 1 of 1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
    Ask FixBot
  7. HP Chromebook 11 G4 Battery Replacement: step 7, image 1 of 3 HP Chromebook 11 G4 Battery Replacement: step 7, image 2 of 3 HP Chromebook 11 G4 Battery Replacement: step 7, image 3 of 3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
    Ask FixBot
  8. HP Chromebook 11 G4 Battery Replacement: step 8, image 1 of 1
    • Remove the keyboard assembly by lifting it off the laptop base.
    Ask FixBot
  9. HP Chromebook 11 G4 Battery Replacement, Battery: step 9, image 1 of 2 HP Chromebook 11 G4 Battery Replacement, Battery: step 9, image 2 of 2
    • Remove the six 4mm Phillips #1 screws.
    Ask FixBot
  10. HP Chromebook 11 G4 Battery Replacement: step 10, image 1 of 2 HP Chromebook 11 G4 Battery Replacement: step 10, image 2 of 2
    • Disconnect the bundled power cable by grasping both edges with your fingers and pulling.
    Ask FixBot
  11. HP Chromebook 11 G4 Battery Replacement: step 11, image 1 of 1
    • Lift the battery out of the laptop.
    Ask FixBot
28 other people completed this guide.
Christopher Flood
611 Reputation
1 Guide authored
Cal Poly, Team S23-G5, Livingston Spring 2017 Member of Cal Poly, Team S23-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G5
3 Members
6 Guides authored
7 Guide Comments
wow so this is what computer technicians do.
88 88 - Reply Share
Christopher, your step by step is superb! I am one grateful chicky. Thanks to your guide, I didn't have to replace my laptop! It worked like a charm, despite not owning a spudger. I had to improvise and used a butter knife for tha unclipping of keyboard and my fingernails to unclip tha component clips and didn't even damage my rubber pads! Thank you so very much!!!
Jammie Brasher - Reply Share
Video was great. Disassembly and assembly took about 1 hour
Jorge De Joya - Reply Share
Measured power supply voltage as 6V. Not sure if this is enough to bring down the computer. Spec says is should be 7.7Vdc.
Excellent! So easy to follow! Thank you for the well written guide and tips.
Martha Webb - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 92
All Time: 64,286
