HP Chromebook 11 G3 Camera Replacement
    1. HP Chromebook 11 G3 Camera Replacement, Keyboard Mount: step 1, image 1 of 2 HP Chromebook 11 G3 Camera Replacement, Keyboard Mount: step 1, image 2 of 2
      • Flip the laptop upside down so that the lid lies flat on the table.
      • Remove the nine 6mm Phillips #00 screws that line the border.
      Ask FixBot
    2. HP Chromebook 11 G3 Camera Replacement: step 2, image 1 of 2 HP Chromebook 11 G3 Camera Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the two rubber feet closest to the hinge using tweezers.
      • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
      • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
      Ask FixBot
    3. HP Chromebook 11 G3 Camera Replacement: step 3, image 1 of 1
      • Flip the laptop so it is in the upright position.
      • Open the lid.
      • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
      • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
      Ask FixBot
    4. HP Chromebook 11 G3 Camera Replacement: step 4, image 1 of 3 HP Chromebook 11 G3 Camera Replacement: step 4, image 2 of 3 HP Chromebook 11 G3 Camera Replacement: step 4, image 3 of 3
      • Tilt the keyboard mount up.
      • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
      • Gently remove both ribbon cables.
      Ask FixBot
    5. HP Chromebook 11 G3 Camera Replacement: step 5, image 1 of 1
      • Lift the keyboard mount out of the laptop.
      Ask FixBot
    1. HP Chromebook 11 G3 Camera Replacement, Display Assembly: step 6, image 1 of 1
      • Gently tug on the black and white wires connected to the Wi-Fi module to disconnect them.
      Ask FixBot
    2. HP Chromebook 11 G3 Camera Replacement: step 7, image 1 of 2 HP Chromebook 11 G3 Camera Replacement: step 7, image 2 of 2
      • Using a spudger, lift the ZIF retaining flap that secures the display’s ribbon cable to the motherboard.
      • Gently pull the ribbon cable out of its socket.
      Ask FixBot
    3. HP Chromebook 11 G3 Camera Replacement: step 8, image 1 of 1
      • Free the wire from the casing.
      Ask FixBot
    4. HP Chromebook 11 G3 Camera Replacement: step 9, image 1 of 1
      • Remove the two 6mm Phillips #00 screws located near the upper left and right corners of the hinge mounts.
      • Hold the lid so that it is folded slightly inwards while removing the screws so that the lid doesn’t fall.
      Ask FixBot
    5. HP Chromebook 11 G3 Camera Replacement: step 10, image 1 of 1
      • Rotate the lid to a 90-degree angle with the table.
      • Shimmy the lid out of the laptop.
      Ask FixBot
    1. HP Chromebook 11 G3 Camera Replacement, Screen Bezel: step 11, image 1 of 3 HP Chromebook 11 G3 Camera Replacement, Screen Bezel: step 11, image 2 of 3 HP Chromebook 11 G3 Camera Replacement, Screen Bezel: step 11, image 3 of 3
      • Use the plastic opening tool to pry the left and right side of the top of the lid, and proceed inwards from the sides.
      • Do not attempt to remove the entire frame; this isn't necessary for removing the camera.
      • Do not pry at the center of the lid; this may damage the camera inside.
      Ask FixBot
    1. HP Chromebook 11 G3 Camera Replacement, Camera: step 12, image 1 of 1
      • Gently remove the slide-out connector near the bottom left corner of the camera mount.
      Ask FixBot
    2. HP Chromebook 11 G3 Camera Replacement: step 13, image 1 of 1
      Buy
      • Locate the two silver strips of tape on each edge of the camera mount.
      • Use tweezers to peel off these strips.
      Ask FixBot
    3. HP Chromebook 11 G3 Camera Replacement: step 14, image 1 of 1
      • Use a plastic opening tool to pry the camera mount out of the lid.
      • Apply force evenly to prevent bending the mount.
      Ask FixBot
    4. HP Chromebook 11 G3 Camera Replacement: step 15, image 1 of 1
      • Lift the camera out of the lid.
      Ask FixBot
3 other people completed this guide.
Rahul Goyal
1,401 Reputation
10 Guides authored
Cal Poly, Team S23-G3, Livingston Spring 2017 Member of Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 1,495
