HP Chromebook 14-x013dx Battery Replacement
  1. HP Chromebook  14-x013dx Battery Replacement, Keyboard, Touchpad: step 1, image 1 of 2 HP Chromebook  14-x013dx Battery Replacement, Keyboard, Touchpad: step 1, image 2 of 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
    Ask FixBot
  2. HP Chromebook  14-x013dx Battery Replacement: step 2, image 1 of 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
    Ask FixBot
  3. HP Chromebook  14-x013dx Battery Replacement: step 3, image 1 of 2 HP Chromebook  14-x013dx Battery Replacement: step 3, image 2 of 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
    Ask FixBot
  4. HP Chromebook  14-x013dx Battery Replacement: step 4, image 1 of 2 HP Chromebook  14-x013dx Battery Replacement: step 4, image 2 of 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
    Ask FixBot
  5. HP Chromebook  14-x013dx Battery Replacement: step 5, image 1 of 3 HP Chromebook  14-x013dx Battery Replacement: step 5, image 2 of 3 HP Chromebook  14-x013dx Battery Replacement: step 5, image 3 of 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
    Ask FixBot
  6. HP Chromebook  14-x013dx Battery Replacement, Battery: step 6, image 1 of 2 HP Chromebook  14-x013dx Battery Replacement, Battery: step 6, image 2 of 2
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
    Ask FixBot
  7. HP Chromebook  14-x013dx Battery Replacement: step 7, image 1 of 2 HP Chromebook  14-x013dx Battery Replacement: step 7, image 2 of 2
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
    Ask FixBot
  8. HP Chromebook  14-x013dx Battery Replacement: step 8, image 1 of 2 HP Chromebook  14-x013dx Battery Replacement: step 8, image 2 of 2
    • Unhook the battery's power connector from the motherboard.
    Ask FixBot
  9. HP Chromebook  14-x013dx Battery Replacement: step 9, image 1 of 1
    • Lift the battery out of the laptop case.
    Ask FixBot
3 other people completed this guide.
NHerbert
602 Reputation
5 Guides authored
USF Tampa, Team S3-G6, Nance Fall 2017 Member of USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 3,319
