HP 8 1401 Rear-Facing Camera Replacement
    1. HP 8 1401 Rear-Facing Camera Replacement, Back Panel: step 1, image 1 of 1
      • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
      Ask FixBot
    2. HP 8 1401 Rear-Facing Camera Replacement: step 2, image 1 of 1
      • Insert the tip of a plastic opening tool in the seam between the front and back panels.
      Ask FixBot
    3. HP 8 1401 Rear-Facing Camera Replacement: step 3, image 1 of 2 HP 8 1401 Rear-Facing Camera Replacement: step 3, image 2 of 2
      • Slide the plastic opening tool around all edges of the device until the back panel detaches.
      • Lift off the back panel.
      Ask FixBot
    1. HP 8 1401 Rear-Facing Camera Replacement, Rear-Facing Camera: step 4, image 1 of 2 HP 8 1401 Rear-Facing Camera Replacement, Rear-Facing Camera: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
      • Lift the rear-facing camera out of its compartment using the tweezers.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 30
All Time: 345
