HP 8 1401 Front-Facing Camera Replacement
    1. HP 8 1401 Front-Facing Camera Replacement, Back Panel: step 1, image 1 of 1
      • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
      Ask FixBot
    2. HP 8 1401 Front-Facing Camera Replacement: step 2, image 1 of 1
      • Insert the tip of a plastic opening tool in the seam between the front and back panels.
      Ask FixBot
    3. HP 8 1401 Front-Facing Camera Replacement: step 3, image 1 of 2 HP 8 1401 Front-Facing Camera Replacement: step 3, image 2 of 2
      • Slide the plastic opening tool around all edges of the device until the back panel detaches.
      • Lift off the back panel.
      Ask FixBot
    1. HP 8 1401 Front-Facing Camera Replacement, Front-Facing Camera: step 4, image 1 of 1
      • Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
      Ask FixBot
    2. HP 8 1401 Front-Facing Camera Replacement: step 5, image 1 of 2 HP 8 1401 Front-Facing Camera Replacement: step 5, image 2 of 2
      • Lift the front-facing camera out of the tablet.
      Ask FixBot
    3. HP 8 1401 Front-Facing Camera Replacement: step 6, image 1 of 1
      • After the front-facing camera has been removed, the tablet should look like this.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 21
All Time: 313
