HP 8 1401 Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
12
Past 30 Days:
51
All Time:
1,349
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide is helpful if you need to replace a dead or damaged battery. Be careful when removing the battery to not bend or puncture it because it may contain hazardous chemicals.
Tools
    1. HP 8 1401 Battery Replacement, Back Panel: step 1, image 1 of 1
      • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
      Ask FixBot
    2. HP 8 1401 Battery Replacement: step 2, image 1 of 1
      • Insert the tip of a plastic opening tool in the seam between the front and back panels.
      Ask FixBot
    3. HP 8 1401 Battery Replacement: step 3, image 1 of 2 HP 8 1401 Battery Replacement: step 3, image 2 of 2
      • Slide the plastic opening tool around all edges of the device until the back panel detaches.
      • Lift off the back panel.
      Ask FixBot
    1. HP 8 1401 Battery Replacement, Battery: step 4, image 1 of 2 HP 8 1401 Battery Replacement, Battery: step 4, image 2 of 2
      • Using a spudger or your fingers, disconnect the power cable by sliding the connector out of the socket on the motherboard.
      Ask FixBot
    2. HP 8 1401 Battery Replacement: step 5, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Using a plastic card or a nylon spudger, carefully pry the battery from the adhesive on the tablet.
      • Do not use a metal spudger, which may damage/puncture the battery and pose a hazard.
      Ask FixBot
    3. HP 8 1401 Battery Replacement: step 6, image 1 of 1
      • Once the battery is removed the battery and tablet should look like this.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 51
All Time: 1,349
