Introduction
This guide will help you to replace your broken speaker step by step. Be very careful when you remove your speaker, since using excessive force may cause damage.
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Tool used on this step:Tweezers$4.99
Use tweezers to push out the speaker connector.
