HP 7 Plus 1302 Power and Volume Button Replacement
    1. HP 7 Plus 1302 Power and Volume Button Replacement, Back Cover: step 1, image 1 of 1
      • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
      • Device should be turned off and unplugged before starting the replacements.
      Ask FixBot
    2. HP 7 Plus 1302 Power and Volume Button Replacement: step 2, image 1 of 2 HP 7 Plus 1302 Power and Volume Button Replacement: step 2, image 2 of 2
      • Use the plastic opening tool to push in between the front and the back of the tablet.
      • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
      • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
      Ask FixBot
    3. HP 7 Plus 1302 Power and Volume Button Replacement: step 3, image 1 of 2 HP 7 Plus 1302 Power and Volume Button Replacement: step 3, image 2 of 2
      • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
      • Remove the back cover.
      Ask FixBot
    1. HP 7 Plus 1302 Power and Volume Button Replacement, Power and Volume Button: step 4, image 1 of 1
      • Locate the power and volume buttons on the right side
      Ask FixBot
    2. HP 7 Plus 1302 Power and Volume Button Replacement: step 5, image 1 of 2 HP 7 Plus 1302 Power and Volume Button Replacement: step 5, image 2 of 2
      • Pop out the power and volume buttons with your hands
      Ask FixBot
Shannon Suttles
225 Reputation
2 Guides authored
IUPUI, Team 1-4, Baechle Spring 2017 Member of IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
4 Members
45 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 571
