HP 7 Plus 1302 Charging Port Replacement
    1. HP 7 Plus 1302 Charging Port Replacement, Back Cover: step 1, image 1 of 1
      • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
      • Device should be turned off and unplugged before starting the replacements.
      Ask FixBot
    2. HP 7 Plus 1302 Charging Port Replacement: step 2, image 1 of 2 HP 7 Plus 1302 Charging Port Replacement: step 2, image 2 of 2
      • Use the plastic opening tool to push in between the front and the back of the tablet.
      • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
      • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
      Ask FixBot
    3. HP 7 Plus 1302 Charging Port Replacement: step 3, image 1 of 2 HP 7 Plus 1302 Charging Port Replacement: step 3, image 2 of 2
      • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
      • Remove the back cover.
      Ask FixBot
    1. HP 7 Plus 1302 Charging Port Replacement, Battery: step 4, image 1 of 2 HP 7 Plus 1302 Charging Port Replacement, Battery: step 4, image 2 of 2
      • Push out the battery connector using the spudger.
      • Swing the battery connector clear of the connector socket.
      Ask FixBot
    2. HP 7 Plus 1302 Charging Port Replacement: step 5, image 1 of 1
      • Lift the battery from the device.
      Ask FixBot
    1. HP 7 Plus 1302 Charging Port Replacement, Motherboard: step 6, image 1 of 2 HP 7 Plus 1302 Charging Port Replacement, Motherboard: step 6, image 2 of 2
      • Pry the connector that attaches the front and back camera with a metal spudger.
      Ask FixBot
    2. HP 7 Plus 1302 Charging Port Replacement: step 7, image 1 of 2 HP 7 Plus 1302 Charging Port Replacement: step 7, image 2 of 2
      • Pull the camera from the connectors.
      Ask FixBot
    3. HP 7 Plus 1302 Charging Port Replacement: step 8, image 1 of 2 HP 7 Plus 1302 Charging Port Replacement: step 8, image 2 of 2
      • Identify the three T5x1mm screws and remove them with a Phillips #000
      Ask FixBot
    4. HP 7 Plus 1302 Charging Port Replacement: step 9, image 1 of 2 HP 7 Plus 1302 Charging Port Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Unplug the connector with the tweezers.
      • Remove the tape.
      Ask FixBot
    5. HP 7 Plus 1302 Charging Port Replacement: step 10, image 1 of 2 HP 7 Plus 1302 Charging Port Replacement: step 10, image 2 of 2
      • Flip the ZIF connector with the metal spudger.
      • Pull the ribbon connector out.
      Ask FixBot
    6. HP 7 Plus 1302 Charging Port Replacement: step 11, image 1 of 3 HP 7 Plus 1302 Charging Port Replacement: step 11, image 2 of 3 HP 7 Plus 1302 Charging Port Replacement: step 11, image 3 of 3
      • Pull the orange tape with the tweezers.
      • Flip the ZIF connector with the spudger.
      • Pull the ribbon connector with the tweezers.
      Ask FixBot
    7. HP 7 Plus 1302 Charging Port Replacement: step 12, image 1 of 1
      • Remove the gray tape below the ribbon connector.
      Ask FixBot
    8. HP 7 Plus 1302 Charging Port Replacement: step 13, image 1 of 2 HP 7 Plus 1302 Charging Port Replacement: step 13, image 2 of 2
      • Flip the ZIF connector.
      • Pull the ribbon connector out with the tweezers.
      Ask FixBot
    9. HP 7 Plus 1302 Charging Port Replacement: step 14, image 1 of 2 HP 7 Plus 1302 Charging Port Replacement: step 14, image 2 of 2
      • Pull the circuit board off.
      Ask FixBot
    1. HP 7 Plus 1302 Charging Port Replacement, Charging Port: step 15, image 1 of 1
      • Desolder the four points on the charging port using the soldering iron.
      • Soldering iron will be hot be careful.
      • For more instructions about how to use the Soldering iron click here.
      Ask FixBot
Damaris Torres-Crespo
204 Reputation
2 Guides authored
IUPUI, Team 1-4, Baechle Spring 2017 Member of IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
4 Members
45 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 24
All Time: 753
