HP 7 PLUS 1301 Speaker Replacement
  1. HP 7 PLUS 1301 Speaker Replacement, Speaker: step 1, image 1 of 2 HP 7 PLUS 1301 Speaker Replacement, Speaker: step 1, image 2 of 2
    • Make sure the device is off and not plugged in before starting.
    • Use the Torx T5 screwdriver and remove the 3mm screws on all four corners of the device.
    Ask FixBot
  2. HP 7 PLUS 1301 Speaker Replacement: step 2, image 1 of 2 HP 7 PLUS 1301 Speaker Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
    Ask FixBot
  3. HP 7 PLUS 1301 Speaker Replacement: step 3, image 1 of 2 HP 7 PLUS 1301 Speaker Replacement: step 3, image 2 of 2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
    Ask FixBot
  4. HP 7 PLUS 1301 Speaker Replacement: step 4, image 1 of 2 HP 7 PLUS 1301 Speaker Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, carefully remove the speaker connector from the socket.
    Ask FixBot
  5. HP 7 PLUS 1301 Speaker Replacement: step 5, image 1 of 3 HP 7 PLUS 1301 Speaker Replacement: step 5, image 2 of 3 HP 7 PLUS 1301 Speaker Replacement: step 5, image 3 of 3
    • Insert a spudger in the bottom right of the speaker. It makes the speaker easier to come off.
    • Carefully remove the speaker with your hand.
    • Some force needs to be applied here due to the adhesive on the other side of the speaker.
    Ask FixBot
Shao-Hung Hsiao
201 Reputation
1 Guide authored
UC Davis, Team S20-G6, Lore Winter 2019 Member of UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 30
All Time: 292
