HP 7 PLUS 1301 Front and Back Camera Replacement
    1. HP 7 PLUS 1301 Front and Back Camera Replacement, Front and Back Camera: step 1, image 1 of 2 HP 7 PLUS 1301 Front and Back Camera Replacement, Front and Back Camera: step 1, image 2 of 2
      • Make sure the device is off and not plugged in before starting.
      • Using a Torx T5 screwdriver, remove the 3mm screws on all four corners of the device.
      Ask FixBot
    2. HP 7 PLUS 1301 Front and Back Camera Replacement: step 2, image 1 of 2 HP 7 PLUS 1301 Front and Back Camera Replacement: step 2, image 2 of 2
      • Using the plastic opening tool, push in between the front, then slide it around.
      • Slide the plastic opening tool all the way around the tablet to separate the back cover.
      • Be careful when trying to remove the back as the screen can be damaged with excessive force.
      Ask FixBot
    3. HP 7 PLUS 1301 Front and Back Camera Replacement: step 3, image 1 of 2 HP 7 PLUS 1301 Front and Back Camera Replacement: step 3, image 2 of 2
      • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
      • Remove the back cover.
      Ask FixBot
    4. HP 7 PLUS 1301 Front and Back Camera Replacement: step 4, image 1 of 1
      • Locate the front and rear cameras.
      Ask FixBot
    5. HP 7 PLUS 1301 Front and Back Camera Replacement: step 5, image 1 of 2 HP 7 PLUS 1301 Front and Back Camera Replacement: step 5, image 2 of 2
      • Using the opening tool, locate the rectangular gray connector near the camera and gently release its connection.
      • Lift the connector out and away from the board.
      • This will come out very easily so don't use much force.
      Ask FixBot
    6. HP 7 PLUS 1301 Front and Back Camera Replacement: step 6, image 1 of 2 HP 7 PLUS 1301 Front and Back Camera Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Gently push the tabs on both sides until the front camera is loose.
      • Using your blunt tweezers, lift the front camera gently away from the board.
      Ask FixBot
    7. HP 7 PLUS 1301 Front and Back Camera Replacement: step 7, image 1 of 3 HP 7 PLUS 1301 Front and Back Camera Replacement: step 7, image 2 of 3 HP 7 PLUS 1301 Front and Back Camera Replacement: step 7, image 3 of 3
      • Using your angled tweezers, gently pry out the back camera.
      • The camera is held down with tape.
      • Lift the back camera out of its socket and gently pull out both cameras.
      Ask FixBot
ahmed musleh
195 Reputation
1 Guide authored
UC Davis, Team S20-G6, Lore Winter 2019 Member of UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 392
