Up to 20% off select tools
HP 550 Notebook LCD Display Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
7
Past 7 Days:
24
Past 30 Days:
110
All Time:
3,555
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Follow this guide to fix your LCD display.
    1. HP 550 Notebook LCD Display Replacement, LCD display: step 1, image 1 of 1
      • Remove the battery
      Ask FixBot
    2. HP 550 Notebook LCD Display Replacement: step 2, image 1 of 3 HP 550 Notebook LCD Display Replacement: step 2, image 2 of 3 HP 550 Notebook LCD Display Replacement: step 2, image 3 of 3
      • Remove the 8 pads and the underlying screws
      Ask FixBot
    3. HP 550 Notebook LCD Display Replacement: step 3, image 1 of 3 HP 550 Notebook LCD Display Replacement: step 3, image 2 of 3 HP 550 Notebook LCD Display Replacement: step 3, image 3 of 3
      • Use a thin tool to separate the lcd frame
      • Unhook the cover on the 2 hinges on the upper side
      Ask FixBot
    4. HP 550 Notebook LCD Display Replacement: step 4, image 1 of 3 HP 550 Notebook LCD Display Replacement: step 4, image 2 of 3 HP 550 Notebook LCD Display Replacement: step 4, image 3 of 3
      • Remove the LCD cover with delicacy, paying attention to the wires and removing any adhesive if present.
      • Remove 4 lcd fixing screws on one side and 4 screws on the other
      • Force the back cover slightly to access the last screw on both sides
      Ask FixBot
    5. HP 550 Notebook LCD Display Replacement: step 5, image 1 of 3 HP 550 Notebook LCD Display Replacement: step 5, image 2 of 3 HP 550 Notebook LCD Display Replacement: step 5, image 3 of 3
      • Disconnect the lcd panel connector
      • Gently lay the LCD panel on the keyboard.
      • Disconnect video display connector.
      Ask FixBot
    6. HP 550 Notebook LCD Display Replacement: step 6, image 1 of 1
      • Remove the LCD panel and replace with the new one
      Ask FixBot
To reassemble the device, follow these instructions in reverse order.
3 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Smilzo
12,407 Reputation
39 Guides authored
2 Guide Comments
what are those two things on top labeled 1 and 2 in the last picture?
Vladut Prcsina - Reply Share
Non ho capito la domanda. Grazie
Smilzo - Reply Share
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 110
All Time: 3,555
