HP 310-1037 Hard Drive Replacement
Views: 6K
View statistics:
Past 24 Hours:
0
Past 7 Days:
25
Past 30 Days:
91
All Time:
5,969
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Here is a HP 310-1037 with a failed hard drive. The Hitachit 1TB hard drive is a common item to fail. The repalcement is very easy and not hidden screws or adhesive. All that is needed is a flathead screwdriver and a Phillips screwdriver.
Tools
    1. HP 310-1037 Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 HP 310-1037 Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 HP 310-1037 Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
      • HP310-1037 Touchsmart PC with a dead hard drive. The hard drive is located behind the stand cover.
      • Lay the PC flat on the front to gain access to the stand cover
      • Remove the single screw that holds the stand cover to the chassis with a flat tip screwdriver
      Ask FixBot
    2. HP 310-1037 Hard Drive Replacement: step 2, image 1 of 3 HP 310-1037 Hard Drive Replacement: step 2, image 2 of 3 HP 310-1037 Hard Drive Replacement: step 2, image 3 of 3
      • Remove the stand cover
      • The hard drive caddy is held in place with 1 Phillips screw
      • Use a #0 Phillips screwdriver to remove that screw
      Ask FixBot
    3. HP 310-1037 Hard Drive Replacement: step 3, image 1 of 3 HP 310-1037 Hard Drive Replacement: step 3, image 2 of 3 HP 310-1037 Hard Drive Replacement: step 3, image 3 of 3
      • Lift the handle on the hard drive caddy
      • and pull it to the backside. This will remove the hard drive caddy from the computer.
      • To remove the hard drive from the caddy, turn it over. There are four Phillips scres that hold the hard drive in place.
      Ask FixBot
    4. HP 310-1037 Hard Drive Replacement: step 4, image 1 of 2 HP 310-1037 Hard Drive Replacement: step 4, image 2 of 2
      • Once the four screws are removed, slide the hard drive out of the caddy.
      • Here is the failed drive. It is a Hitachi HDS721010CLA332. Failure with this drive is all to common.
      Ask FixBot
9 other people completed this guide.
oldturkey03
864,822 Reputation
123 Guides authored
2 Guide Comments
This one made me laugh - Remove two screws. Pull the drive out. Difficulty: Moderate.
LOL
Justin Coope - Reply Share
Used this guide to get my failing hard drive, thanks!
AdamG - Reply Share
Past 24 Hours: 0
Past 7 Days: 25
Past 30 Days: 91
All Time: 5,969
