HP 255 G8 Hard Drive Replacement
    1. HP 255 G8 Hard Drive Replacement, Hard drive: step 1, image 1 of 2 HP 255 G8 Hard Drive Replacement, Hard drive: step 1, image 2 of 2
      • Ensure that your laptop is powered off and it is disconnected from all peripherals and the charger.
      • Flip your laptop over so the bottom case is facing up.
      • Use a spudger to remove the two rubber strips covering the screws.
      • Keep the screw covers to replace them after you have finished the repair.
      Ask FixBot
    2. HP 255 G8 Hard Drive Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 10 screws securing the bottom case.
      Ask FixBot
    3. HP 255 G8 Hard Drive Replacement: step 3, image 1 of 1
      • Slide the optical drive/disk drive out to remove it.
      • If you are struggling to remove the optical drive, hold the laptop down with your right hand and continue to pull with your left.
      Ask FixBot
    4. HP 255 G8 Hard Drive Replacement: step 4, image 1 of 2 HP 255 G8 Hard Drive Replacement: step 4, image 2 of 2
      • Carefully lift the back panel off of the laptop.
      • Use a Phillips #00 screwdriver to remove four screws securing the hard drive.
      Ask FixBot
    5. HP 255 G8 Hard Drive Replacement: step 5, image 1 of 1
      • Carefully lift and remove the hard drive bracket.
      Ask FixBot
    6. HP 255 G8 Hard Drive Replacement: step 6, image 1 of 3 HP 255 G8 Hard Drive Replacement: step 6, image 2 of 3 HP 255 G8 Hard Drive Replacement: step 6, image 3 of 3
      • Lift the hard drive and hold it at a 30-degree angle.
      • Detach the hard drive from the connector by sliding the hard drive to the left.
      Ask FixBot
Columbus Souratha
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 38
Past 30 Days: 145
All Time: 1,757
