HP 250 G7 SSD Replacement
    1. HP 250 G7 SSD Replacement, Lower Case: step 1, image 1 of 2 HP 250 G7 SSD Replacement, Lower Case: step 1, image 2 of 2
      • Unplug the charger and all peripheries. Shut down the laptop before beginning disassembly.
      • Flip the laptop so its underside is facing up.
      • Use a hair dryer to lightly heat the rubber feet.
      • Use a spudger to lift and remove the rubber feet.
      • If you intend to reuse the feet, take care not to tear or warp the rubber feet during removal. Reapply adhesive during reinstallation.
      Ask FixBot
    2. HP 250 G7 SSD Replacement: step 2, image 1 of 3 HP 250 G7 SSD Replacement: step 2, image 2 of 3 HP 250 G7 SSD Replacement: step 2, image 3 of 3
      • Remove the eleven 9 mm-long Phillips #1 screws securing the lower case.
      Ask FixBot
    3. HP 250 G7 SSD Replacement: step 3, image 1 of 3 HP 250 G7 SSD Replacement: step 3, image 2 of 3 HP 250 G7 SSD Replacement: step 3, image 3 of 3
      • Insert an opening pick or opening tool into the seam between the lower case and palm rest assembly.
      • Slide the opening pick around the entire perimeter, while prying every couple of centimeters to release the retaining clips.
      • Remove the lower case.
      Ask FixBot
    1. HP 250 G7 SSD Replacement, Battery: step 4, image 1 of 1
      • Remove the three 8 mm-long Phillips #1 screws securing the battery.
      Ask FixBot
    2. HP 250 G7 SSD Replacement: step 5, image 1 of 2 HP 250 G7 SSD Replacement: step 5, image 2 of 2
      • Lift the battery up and away from the connector.
      • Remove the battery.
      Ask FixBot
    1. HP 250 G7 SSD Replacement, SSD: step 6, image 1 of 3 HP 250 G7 SSD Replacement, SSD: step 6, image 2 of 3 HP 250 G7 SSD Replacement, SSD: step 6, image 3 of 3
      • If your SSD comes with an extender, remove this first by unscrewing the M2.0 x 3.0 screw on the edge of the extender using a Phillips #1 screwdriver.
      • Remove the M2.0 x 3.0 Phillips #1 screw securing the SSD.
      Ask FixBot
    2. HP 250 G7 SSD Replacement: step 7, image 1 of 3 HP 250 G7 SSD Replacement: step 7, image 2 of 3 HP 250 G7 SSD Replacement: step 7, image 3 of 3
      • If you have an extender remove this first by pulling it away from the SSD and computer.
      • Pull the SSD module out from the socket.
      • Make sure to be careful when removing the SSD so as not to damage the bracket holding the SSD.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 55
Past 30 Days: 215
All Time: 586
