Up to 20% off select tools
HP 250 G7 RAM Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
41
Past 30 Days:
207
All Time:
736
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Is your HP 250 G7 running slowly, struggling with multitasking, or frequently maxing out memory usage? Upgrading the RAM can significantly improve performance. This guide will show you how to access and replace the memory module.
Before starting this repair, check the HP 250 G7 Troubleshooting pages to confirm that insufficient RAM is the cause of your performance issues.
To begin:
  • Power off the laptop
  • Disconnect anything plugged into the laptop
Safety Warnings:
  • Disconnect the battery before touching internal components
  • Avoid static discharge, as RAM is highly sensitive to ESD
  • Do not use metal pry tools when opening the laptop
  • Handle the RAM module by the edges to avoid damaging the contacts
RAM Specs:
Memory module, 8 GB
Memory module, 4 GB
    1. HP 250 G7 RAM Replacement, Lower Case: step 1, image 1 of 2 HP 250 G7 RAM Replacement, Lower Case: step 1, image 2 of 2
      • Unplug the charger and all peripheries. Shut down the laptop before beginning disassembly.
      • Flip the laptop so its underside is facing up.
      • Use a hair dryer to lightly heat the rubber feet.
      • Use a spudger to lift and remove the rubber feet.
      • If you intend to reuse the feet, take care not to tear or warp the rubber feet during removal. Reapply adhesive during reinstallation.
      Ask FixBot
    2. HP 250 G7 RAM Replacement: step 2, image 1 of 3 HP 250 G7 RAM Replacement: step 2, image 2 of 3 HP 250 G7 RAM Replacement: step 2, image 3 of 3
      • Remove the eleven 9 mm-long Phillips #1 screws securing the lower case.
      Ask FixBot
    3. HP 250 G7 RAM Replacement: step 3, image 1 of 3 HP 250 G7 RAM Replacement: step 3, image 2 of 3 HP 250 G7 RAM Replacement: step 3, image 3 of 3
      • Insert an opening pick or opening tool into the seam between the lower case and palm rest assembly.
      • Slide the opening pick around the entire perimeter, while prying every couple of centimeters to release the retaining clips.
      • Remove the lower case.
      Ask FixBot
    1. HP 250 G7 RAM Replacement, Battery: step 4, image 1 of 1
      • Remove the three 8 mm-long Phillips #1 screws securing the battery.
      Ask FixBot
    2. HP 250 G7 RAM Replacement: step 5, image 1 of 2 HP 250 G7 RAM Replacement: step 5, image 2 of 2
      • Lift the battery up and away from the connector.
      • Remove the battery.
      Ask FixBot
    1. HP 250 G7 RAM Replacement, RAM: step 6, image 1 of 3 HP 250 G7 RAM Replacement, RAM: step 6, image 2 of 3 HP 250 G7 RAM Replacement, RAM: step 6, image 3 of 3
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • Be cautious with force, as you don't want to break the spring mechanism.
      • Gently grasp the edges of the memory module and pull it away from the slot.
      • When you replace memory, after inserting it into the slot, gently push down and clips will snap it in place.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
Author
with
Brenden Daisy
364 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 41
Past 30 Days: 207
All Time: 736
