HP 250 G7 Lower Case Replacement
    1. HP 250 G7 Lower Case Replacement, Lower Case: step 1, image 1 of 2 HP 250 G7 Lower Case Replacement, Lower Case: step 1, image 2 of 2
      • Unplug the charger and all peripheries. Shut down the laptop before beginning disassembly.
      • Flip the laptop so its underside is facing up.
      • Use a hair dryer to lightly heat the rubber feet.
      • Use a spudger to lift and remove the rubber feet.
      • If you intend to reuse the feet, take care not to tear or warp the rubber feet during removal. Reapply adhesive during reinstallation.
      Ask FixBot
    2. HP 250 G7 Lower Case Replacement: step 2, image 1 of 3 HP 250 G7 Lower Case Replacement: step 2, image 2 of 3 HP 250 G7 Lower Case Replacement: step 2, image 3 of 3
      • Remove the eleven 9 mm-long Phillips #1 screws securing the lower case.
      Ask FixBot
    3. HP 250 G7 Lower Case Replacement: step 3, image 1 of 3 HP 250 G7 Lower Case Replacement: step 3, image 2 of 3 HP 250 G7 Lower Case Replacement: step 3, image 3 of 3
      • Insert an opening pick or opening tool into the seam between the lower case and palm rest assembly.
      • Slide the opening pick around the entire perimeter, while prying every couple of centimeters to release the retaining clips.
      • Remove the lower case.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 126
All Time: 349
