Tools
Spudger4.9
Introduction
Go to step 1 ↓If your HP 250 G7 screen does not turn on, has dead pixels, or is damaged you should consider replacing it. This guide will show you how to remove the existing screen and install a new one.
To begin:
- Power off the laptop
- Disconnect anything plugged into the laptop
Safety Warnings
- Disconnect the battery before touching the Display
- Avoid static discharge (ESD)
- Use a plastic spudger, not metal tools
Unplug the charger and all peripheries. Shut down the laptop before beginning disassembly.
Flip the laptop so its underside is facing up.
Use a hair dryer to lightly heat the rubber feet.
Use a spudger to lift and remove the rubber feet.
Pull back the tape holding the display connector.
Disconnect the display connector from the board.
Remove the cable from the clip so that it is out of the way.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
3 other people completed this guide.
