Introduction
Go to step 1 ↓If your HP 250 G7 is overheating, shutting down unexpectedly, or the fan is making grinding, rattling, or unusually loud noises, the cooling fan may need to be replaced. A failing fan can lead to thermal throttling and long‑term damage to internal components, so addressing it early is important.
Before starting this repair, check the HP 250 G7 Troubleshooting pages to confirm that the fan is the source of the issue.
To begin:
- Power off the laptop
- Disconnect anything plugged into the laptop
Safety Warnings
- Disconnect the battery before touching internal components
- Avoid static discharge
- Do not use metal pry tools
- Handle the fan by the edges
Fan Specs:
- Fan Model: L20474‑001
- Type: CPU Cooling Fan (4‑pin) Voltage: 5V Current: 0.35A (typical) Wattage: 2.25–2.5W RPM: ~2960–3500
- HP Part Number: L20474‑001
- Regulatory Part Numbers: DC28000L8D0
- Product Code: L20474‑001_V1
Tools
Unplug the charger and all peripheries. Shut down the laptop before beginning disassembly.
Flip the laptop so its underside is facing up.
Use a hair dryer to lightly heat the rubber feet.
Use a spudger to lift and remove the rubber feet.
Slide the fan connector directly out of its motherboard socket.
Remove the 6 mm-long Phillips #1 screw that holds the fan in place.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
