Up to 20% off select tools
HP 24-G014 disassembly
Views: 11K
View statistics:
Past 24 Hours:
9
Past 7 Days:
64
Past 30 Days:
259
All Time:
11,116
Comments: 1
1 comment on steps.
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This Guide will show you how to get inside of the HP 24-G014 All in one Desktop.
    1. HP 24-G014 disassembly, The Stand: step 1, image 1 of 2 HP 24-G014 disassembly, The Stand: step 1, image 2 of 2
      • Flipping the device over here we see two Philips screws holding the stand to the computer.
      • Using a basic screw driver you will most likely find in your garage or a junk drawer we can remove these two screws.
      Ask FixBot
    2. HP 24-G014 disassembly, Removing said stand: step 2, image 1 of 1
      • After removing the two screws you can pull off the stand.
      Ask FixBot
    3. HP 24-G014 disassembly, Remove the screw inside the stand slot: step 3, image 1 of 2 HP 24-G014 disassembly, Remove the screw inside the stand slot: step 3, image 2 of 2
      • Inside the stand slot there is an extra screw using the same screw driver remove the screw.
      Ask FixBot
    4. HP 24-G014 disassembly: step 4, image 1 of 3 HP 24-G014 disassembly: step 4, image 2 of 3 HP 24-G014 disassembly: step 4, image 3 of 3
      • After the screw in the stand slot is removed there are clips holding the display to the body of the system.
      • Using a prying tool such as an iFixit metal spudger or Jimmy tool you can lift the display from the body.
      • Don’t worry about accidentally striking the components as they are pretty far away except for the bottom since the speakers are there.
      • One last thing before going to the other step. I highly don’t recommend using something such as a big flat head screw driver, butter knife, or sharp knifes. But if you must you can use them.
      Ask FixBot
    5. HP 24-G014 disassembly, Removing the Display from the body.: step 5, image 1 of 1
      • After unclipping the display from the body be very gentle! As there are wires and a display connector attached to the screen.
      • To prevent damage you should open the system from bottom to top (where the HP logo is).
      Ask FixBot
That’s it you’re done!
I am not responsible for any damages done to your device if you break it during repair.
8 other people completed this guide.
Author
with
Hayden
323 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 64
Past 30 Days: 259
All Time: 11,116
