Up to 20% off select tools
HP 225 G7 Memory (RAM) Replacement / Upgrade
Views: 2.2K
View statistics:
Past 24 Hours:
8
Past 7 Days:
41
Past 30 Days:
169
All Time:
2,224
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Sometimes you might need to replace the RAM inside of your laptop, or you might want to upgrade your RAM. This guide will help you open your HP 255 G7, locate the RAM, and remove it and reinstall it.
    1. HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove Rubber Legs: step 1, image 1 of 2 HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove Rubber Legs: step 1, image 2 of 2
      • Use the spatula to remove the long rubber leg from the bottom of the laptop.
      • Repeat the same for the second rubber on the bottom.
      Ask FixBot
    2. HP 225 G7 Memory (RAM) Replacement / Upgrade, Unscrew Bottom Cover: step 2, image 1 of 2 HP 225 G7 Memory (RAM) Replacement / Upgrade, Unscrew Bottom Cover: step 2, image 2 of 2
      • Unscrew all the screws on the bottom of the laptop including the ones that were under the rubber legs.
      Ask FixBot
    3. HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove CD/DVD Drive: step 3, image 1 of 3 HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove CD/DVD Drive: step 3, image 2 of 3 HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove CD/DVD Drive: step 3, image 3 of 3
      • Push the CD drive outwards.
      • Then pull the CD drive out.
      Ask FixBot
    4. HP 225 G7 Memory (RAM) Replacement / Upgrade, Open The Laptop: step 4, image 1 of 1
      • Then, open the laptop like you normally would if you were working.
      Ask FixBot
    5. HP 225 G7 Memory (RAM) Replacement / Upgrade, Insert A Pick: step 5, image 1 of 1
      • Carefully insert a guitar pick under the touchpad, and leave it on there.
      Ask FixBot
    6. HP 225 G7 Memory (RAM) Replacement / Upgrade, Insert All Picks Around The Laptop: step 6, image 1 of 1
      • Then, slowly insert all 6 picks all around the laptop.
      • It is best to leave the picks on while you are inserting other picks so you prevent accidentally pushing on the laptop and putting the cover back on.
      Ask FixBot
    7. HP 225 G7 Memory (RAM) Replacement / Upgrade, Pry Open The Cover: step 7, image 1 of 1
      • Remove the picks.
      • Pull the cover and the main body of the laptop apart.
      • If you find a lot of resistance while trying to pull the bottom cover off, close the screen because the hinges often "hold" the bottom cover. If you still find a lot resistance, check for any forgotten screws. Don't apply too much force if you are having difficulty.
      Ask FixBot
    8. HP 225 G7 Memory (RAM) Replacement / Upgrade, How The Laptop Should Look Like: step 8, image 1 of 1
      • After prying the bottom cover off, the bottom of the laptop should look like that.
      Ask FixBot
    9. HP 225 G7 Memory (RAM) Replacement / Upgrade, Locate The RAM: step 9, image 1 of 1
      • Locate the RAM dim on the upper right corner of the laptop. ("upper" when the screen hinge is facing upwards)
      Ask FixBot
    10. HP 225 G7 Memory (RAM) Replacement / Upgrade, "Unlock" The RAM Dim: step 10, image 1 of 2 HP 225 G7 Memory (RAM) Replacement / Upgrade, "Unlock" The RAM Dim: step 10, image 2 of 2
      • Use a spudger to push both of the clips outwards. Then the dim should pop upwards.
      Ask FixBot
    11. HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove The RAM Dim: step 11, image 1 of 1
      • Then, you can simply pull the RAM dim outwards, and remove it.
      Ask FixBot
      • Insert the new dim in the slot.
      Ask FixBot
      • Then, push downwards on the dim to lock it in place.
      Ask FixBot
4 other people completed this guide.
Author
with
Stratos Thivaios
1,510 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 41
Past 30 Days: 169
All Time: 2,224
