HP 2000-427CL CPU Cooler Replacement
    1. HP 2000-427CL CPU Cooler Replacement, Remove battery: step 1, image 1 of 1
      • With the battery facing towards you, slide the latch to the right.
      • Grab the battery as it lifts out of the laptop.
      Ask FixBot
    1. HP 2000-427CL CPU Cooler Replacement, Remove keyboard: step 2, image 1 of 3 HP 2000-427CL CPU Cooler Replacement, Remove keyboard: step 2, image 2 of 3 HP 2000-427CL CPU Cooler Replacement, Remove keyboard: step 2, image 3 of 3
      • Remove the three M2.5x5 Philips screws securing the keyboard.
      • Remove the memory cover.
      • Remove the single remaining M2.5x5 Philips screw securing the keyboard.
      • Flip the laptop right side-up, and open the screen.
      • Pop each keyboard clip with a spudger, pulling up on the keyboard as you do it. Try not to pry, but rather move the clips, or else you risk damaging the palmrest.
      • Undo the keyboard connector clip, and remove the cable.
      • Remove the single screw that was hidden under the keyboard.
      • Also undo every other visible connector, that being the power button, touchpad, and touchpad button connectors.
      Ask FixBot
    2. HP 2000-427CL CPU Cooler Replacement, Remove palmrest: step 3, image 1 of 1
      • Remove the hard drive cover, and then remove the three screws hidden underneath it.
      • Remove the hard drive, and remove the single hidden M2.5x5 screw under it. Also remove the connector that connects the SATA connector (so many connections!) to the motherboard.
      • Remove the eight M2.5x5 Philips screws securing the palmrest.
      • Remove the two long Philips screws securing the palmrest.
      • Remove the four remaining Philips screws securing the palmrest.
      • Remove the wireless card.
      • Also remove the DC jack connector.
      Ask FixBot
    3. HP 2000-427CL CPU Cooler Replacement, Remove motherboard: step 4, image 1 of 1
      • Remove all connectors from the motherboard.
      • Remove the three M2.5x5 screws from the left speaker, and remove the speaker.
      • After removing the speaker, remove the single screw securing the left hinge to the base.
      • Remove the single screw securing the motherboard to the base.
      • Lift the motherboard up and out.
      Ask FixBot
    4. HP 2000-427CL CPU Cooler Replacement, Remove cooler: step 5, image 1 of 1
      • Remove the four captive Philips screws securing the cooler to the motherboard. You're done!
      • Be sure to use alcohol to clean the thermal paste, and then apply new thermal paste.
      Ask FixBot
Joseph Sctbunio
7,930 Reputation
42 Guides authored
1 Guide Comment
Anyway you could add photos of how you can reconnect the keyboard to the motherboard with all the ribbon cables? I am having a very difficult time trying to figure out how I can reconnect them as they are very short and there is really no space to lift the keyboard high enough to get the cables slotted.
Latiron London - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 112
All Time: 1,065
