HP 2000 - 2D22DX Wireless Card Replacement
    1. HP 2000 - 2D22DX Wireless Card Replacement, Battery: step 1, image 1 of 2 HP 2000 - 2D22DX Wireless Card Replacement, Battery: step 1, image 2 of 2
      • Flip the device over and locate the battery compartment.
      • Slide the battery release latch to the left until the battery is detached from its slot.
      • A distinguishable pop will be heard when the battery is fully released.
      Ask FixBot
    2. HP 2000 - 2D22DX Wireless Card Replacement: step 2, image 1 of 2 HP 2000 - 2D22DX Wireless Card Replacement: step 2, image 2 of 2
      • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
      Ask FixBot
    1. HP 2000 - 2D22DX Wireless Card Replacement, Wireless Card: step 3, image 1 of 2 HP 2000 - 2D22DX Wireless Card Replacement, Wireless Card: step 3, image 2 of 2
      • Locate the RAM compartment cover below the battery compartment.
      • Locate the Phillips head screw securing RAM compartment to plastic chassis.
      • Loosen screw that is securing the RAM compartment with #00 Phillips head screwdriver.
      • Screw is permanently attached to the RAM compartment cover. Do not try to remove completely.
      Ask FixBot
    2. HP 2000 - 2D22DX Wireless Card Replacement: step 4, image 1 of 2 HP 2000 - 2D22DX Wireless Card Replacement: step 4, image 2 of 2
      • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
      • When unclipped completely, pull the compartment door out and away from the chassis.
      Ask FixBot
    3. HP 2000 - 2D22DX Wireless Card Replacement: step 5, image 1 of 1
      • Locate the wireless module next to the RAM slots.
      Ask FixBot
    4. HP 2000 - 2D22DX Wireless Card Replacement: step 6, image 1 of 3 HP 2000 - 2D22DX Wireless Card Replacement: step 6, image 2 of 3 HP 2000 - 2D22DX Wireless Card Replacement: step 6, image 3 of 3
      • Locate the gold connecting wire attached to the wireless module. It is labeled with a small sticker that has a circled number one.
      • Using a plastic spudger, disconnect the gold-end of the connecting wire from the wireless module.
      • Use a slow, prying motion as if pulling a nail out of wood.
      • Be very gentle with the gold wire and its respective port on the wireless module. Both are very fragile and can be easily ruined.
      Ask FixBot
    5. HP 2000 - 2D22DX Wireless Card Replacement: step 7, image 1 of 3 HP 2000 - 2D22DX Wireless Card Replacement: step 7, image 2 of 3 HP 2000 - 2D22DX Wireless Card Replacement: step 7, image 3 of 3
      • Locate the small Phillips head screw in the top right corner of the wireless module.
      • Using a #00 Phillips head screwdriver, remove the screw and set aside.
      • The wireless module should now pop up from its slot at a 45 degree angle.
      Ask FixBot
    6. HP 2000 - 2D22DX Wireless Card Replacement: step 8, image 1 of 1
      • Slowly slide the wireless module straight out from its slot in the logic board.
      • Maintain the 45 degree angle of the wireless module until all pins are disconnected. Failure to do so may result in breaking the wireless module connecting pins.
      Ask FixBot
5 other people completed this guide.
Conor Most
2,799 Reputation
6 Guides authored
Cal Poly, Team 3-40, Maness Spring 2014 Member of Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 102
All Time: 2,748
