HP 2000 - 2D22DX Optical Drive Replacement
    1. HP 2000 - 2D22DX Optical Drive Replacement, Battery: step 1, image 1 of 2 HP 2000 - 2D22DX Optical Drive Replacement, Battery: step 1, image 2 of 2
      • Flip the device over and locate the battery compartment.
      • Slide the battery release latch to the left until the battery is detached from its slot.
      • A distinguishable pop will be heard when the battery is fully released.
      Ask FixBot
    2. HP 2000 - 2D22DX Optical Drive Replacement: step 2, image 1 of 2 HP 2000 - 2D22DX Optical Drive Replacement: step 2, image 2 of 2
      • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
      Ask FixBot
    1. HP 2000 - 2D22DX Optical Drive Replacement, Hard Drive: step 3, image 1 of 2 HP 2000 - 2D22DX Optical Drive Replacement, Hard Drive: step 3, image 2 of 2
      • Loosen the Phillips #00 screw securing the RAM compartment cover.
      • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
      Ask FixBot
    2. HP 2000 - 2D22DX Optical Drive Replacement: step 4, image 1 of 2 HP 2000 - 2D22DX Optical Drive Replacement: step 4, image 2 of 2
      • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
      • When unclipped completely, pull the compartment door out and away from the chassis.
      Ask FixBot
    3. HP 2000 - 2D22DX Optical Drive Replacement: step 5, image 1 of 3 HP 2000 - 2D22DX Optical Drive Replacement: step 5, image 2 of 3 HP 2000 - 2D22DX Optical Drive Replacement: step 5, image 3 of 3
      • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
      • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
      • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
      Ask FixBot
    4. HP 2000 - 2D22DX Optical Drive Replacement: step 6, image 1 of 3 HP 2000 - 2D22DX Optical Drive Replacement: step 6, image 2 of 3 HP 2000 - 2D22DX Optical Drive Replacement: step 6, image 3 of 3
      • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
      • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
      Ask FixBot
    5. HP 2000 - 2D22DX Optical Drive Replacement: step 7, image 1 of 3 HP 2000 - 2D22DX Optical Drive Replacement: step 7, image 2 of 3 HP 2000 - 2D22DX Optical Drive Replacement: step 7, image 3 of 3
      • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
      • Lift the hard drive out and away from its socket in the plastic chassis.
      Ask FixBot
    1. HP 2000 - 2D22DX Optical Drive Replacement, Optical Drive: step 8, image 1 of 2 HP 2000 - 2D22DX Optical Drive Replacement, Optical Drive: step 8, image 2 of 2
      • Locate the Phillips-head screw on the left side of the hard drive recess, indicated by a red circle.
      • Use a #00 Phillips head screwdriver to remove the small screw. Consider using a magnetized screwdriver.
      Ask FixBot
    2. HP 2000 - 2D22DX Optical Drive Replacement: step 9, image 1 of 3 HP 2000 - 2D22DX Optical Drive Replacement: step 9, image 2 of 3 HP 2000 - 2D22DX Optical Drive Replacement: step 9, image 3 of 3
      • Once the securing screw is removed, the optical drive can be pulled from its slot easily.
      • Use your fingers to pull the optical drive away slowly from its position in the plastic chassis.
      • The optical drive should slide out very easily. If you fell resistance, do not pull too hard. Something may be caught, and you might damage the optical drive's connections.
      Ask FixBot
3 other people completed this guide.
Conor Most
2,799 Reputation
6 Guides authored
Cal Poly, Team 3-40, Maness Spring 2014 Member of Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 113
All Time: 2,268
