HP 2000 - 2D22DX Hard Drive Replacement
    1. HP 2000 - 2D22DX Hard Drive Replacement, Battery: step 1, image 1 of 2 HP 2000 - 2D22DX Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Flip the device over and locate the battery compartment.
      • Slide the battery release latch to the left until the battery is detached from its slot.
      • A distinguishable pop will be heard when the battery is fully released.
      Ask FixBot
    2. HP 2000 - 2D22DX Hard Drive Replacement: step 2, image 1 of 2 HP 2000 - 2D22DX Hard Drive Replacement: step 2, image 2 of 2
      • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
      Ask FixBot
    1. HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
      • Loosen the Phillips #00 screw securing the RAM compartment cover.
      • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
      Ask FixBot
    2. HP 2000 - 2D22DX Hard Drive Replacement: step 4, image 1 of 2 HP 2000 - 2D22DX Hard Drive Replacement: step 4, image 2 of 2
      • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
      • When unclipped completely, pull the compartment door out and away from the chassis.
      Ask FixBot
    3. HP 2000 - 2D22DX Hard Drive Replacement: step 5, image 1 of 3 HP 2000 - 2D22DX Hard Drive Replacement: step 5, image 2 of 3 HP 2000 - 2D22DX Hard Drive Replacement: step 5, image 3 of 3
      • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
      • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
      • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
      Ask FixBot
    4. HP 2000 - 2D22DX Hard Drive Replacement: step 6, image 1 of 3 HP 2000 - 2D22DX Hard Drive Replacement: step 6, image 2 of 3 HP 2000 - 2D22DX Hard Drive Replacement: step 6, image 3 of 3
      • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
      • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
      Ask FixBot
    5. HP 2000 - 2D22DX Hard Drive Replacement: step 7, image 1 of 3 HP 2000 - 2D22DX Hard Drive Replacement: step 7, image 2 of 3 HP 2000 - 2D22DX Hard Drive Replacement: step 7, image 3 of 3
      • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
      • Lift the hard drive out and away from its socket in the plastic chassis.
      Ask FixBot
28 other people completed this guide.
Conor Most
2,799 Reputation
6 Guides authored
Cal Poly, Team 3-40, Maness Spring 2014 Member of Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 121
All Time: 15,929
